Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95-
Remove five screws securing the logic board connector bracket, of the following lengths:
Three 1.0 mm Y000 screws
One 1.3 mm Y000 screw
One 3.7 mm Phillips screw
Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Use a spudger or a fingernail to pry up and disconnect the front panel sensor assembly connector.
Use a spudger or a fingernail to disconnect the OLED panel cable connector.
Use a spudger or fingernail to pry the digitizer cable connector up from its socket.
Carefully lift the cable until the adhesive separates.
Uma outra pessoa concluiu este guia.
