Ir para o conteúdo principal
iPhone 8 SIM Card Replacement
O que você precisa
  1. iPhone 8 SIM Card Replacement, Remove the SIM card: passo 1, imagem 1 %32 iPhone 8 SIM Card Replacement, Remove the SIM card: passo 1, imagem 2 %32
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
    Pergunte ao FixBot
    Comentar
  2. iPhone 8 SIM Card Replacement: passo 2, imagem 1 %32 iPhone 8 SIM Card Replacement: passo 2, imagem 2 %32
    • Remove the SIM card tray from the iPhone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM card tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM card tray to protect your iPhone's internal components.
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
343.036 Reputação
Autoria de 914 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 27.514 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 74
Últimos 30 dias: 347
Ao todo: 107,089
