Introdução
This is an extremely complex repair, with limited guidance, to replace the cover glass of the iPhone 6s Plus display. If you are looking for a simpler guide, follow the official iFixit iPhone 6s Plus screen replacement guide instead.
O que você precisa
In this video you will learn how to replace the glass in your Apple iPhone 6+ smartphone. To make it as it should be done watch the recording carefully.
10 outras pessoas executaram este guia.
3 comentários
I think the YouTube video that shows how to do it with dry ice is better than this video.
How much is it at ifix in oneonta wall-mart charge to replace an iphone 6 plus screen
Katie Oldfield
Its hard because this guy isn’t very explanatory and its hard to see different steps. The video is ok
jerodancira - Responder
Thanks for the advice, I’m trying to get better and explain more in my new recordings. Thanks for watching and good luckc with the repairs!
Alex Sander -
does the glass already have the OCA on it? Is the laminator under a vacuum?
Vince Anderson - Responder
In this tutorial there isn’t OCA under it, but I also prepared new guide where OCA is already on the screen, you can find it here: iPhone 6 original apple Glass / Screen Replacement new 2018 method
Alex Sander - Responder
This is a terrible video because we see his arm more than the repair itself. Please remove this video and have one of your experts do it.
David York - Responder
