Ir para o conteúdo principal
iPhone 6s Plus Glass-Only Screen Repair
O que você precisa
    • In this video you will learn how to replace the glass in your Apple iPhone 6+ smartphone. To make it as it should be done watch the recording carefully.
    Its hard because this guy isn’t very explanatory and its hard to see different steps. The video is ok
    jerodancira - Responder
    Thanks for the advice, I’m trying to get better and explain more in my new recordings. Thanks for watching and good luckc with the repairs!
    Alex Sander -
    does the glass already have the OCA on it? Is the laminator under a vacuum?
    Vince Anderson - Responder
    In this tutorial there isn’t OCA under it, but I also prepared new guide where OCA is already on the screen, you can find it here: iPhone 6 original apple Glass / Screen Replacement new 2018 method
    Alex Sander - Responder
    This is a terrible video because we see his arm more than the repair itself. Please remove this video and have one of your experts do it.
    David York - Responder
Conclusão
10 outras pessoas executaram este guia.
Alex Sander
Membro desde: 02/28/17
38.867 Reputação
Autoria de 201 guias
3 comentários
I think the YouTube video that shows how to do it with dry ice is better than this video.
Matthew Elvey - Responder
How much is it at ifix in oneonta wall-mart charge to replace an iphone 6 plus screen
megan walley - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 50
Ao todo: 26,597
