Ir para o conteúdo principal
iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement
O que você precisa
  1. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement, Pentalobe Screws: passo 1, imagem 1 %32
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement, Anti-Clamp instructions: passo 2, imagem 1 %32 iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement, Anti-Clamp instructions: passo 2, imagem 2 %32 iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement, Anti-Clamp instructions: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 3, imagem 1 %32 iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 3, imagem 2 %32 iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 3, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick or tool under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement, Front Panel Assembly: passo 4, imagem 1 %32
    • Use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  5. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 5, imagem 1 %32
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  6. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 6, imagem 1 %32 iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 6, imagem 2 %32
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  7. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 7, imagem 1 %32 iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 7, imagem 2 %32 iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 7, imagem 3 %32
    • Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  8. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 8, imagem 1 %32 iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 8, imagem 2 %32
    • Several clips along the top edge of the front panel form a partial hinge, allowing the front panel assembly to swing open like a book.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  9. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 9, imagem 1 %32
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.3 mm screw
    • One 3.1 mm screw
  10. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 10, imagem 1 %32
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 11, imagem 1 %32
    • Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  12. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 12, imagem 1 %32
    • Remove the following Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.5 mm screw
    • One 2.9 mm screw
    • Do not attempt to insert longer screws into the red marked screw holes. Doing so may result in irreparable damage to the logic board.
  13. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 13, imagem 1 %32
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 14, imagem 1 %32 iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 14, imagem 2 %32
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
  15. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 15, imagem 1 %32 iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 15, imagem 2 %32
    • Disconnect the home button cable connector.
  16. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 16, imagem 1 %32 iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 16, imagem 2 %32
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a plastic opening tool to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  17. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 17, imagem 1 %32 iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 17, imagem 2 %32
    • Finally, disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  18. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 18, imagem 1 %32
    • Remove the front panel assembly from the rear case.
  19. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement, Earpiece Speaker: passo 19, imagem 1 %32
    • Remove the following Phillips screws securing the upper component bracket:
    • One 1.5 mm screw
    • Two 2.3 mm screws
  20. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 20, imagem 1 %32
    • Lift and remove the earpiece bracket from the display assembly.
  21. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 21, imagem 1 %32
    • Use a the flat end of a spudger to pry up the front-facing camera and display cables, and gently push them aside.
  22. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 22, imagem 1 %32
    • Use a pair of tweezers to firmly grasp and remove the earpiece speaker from the display assembly.
  23. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement, Front Facing Camera and Sensor Assembly: passo 23, imagem 1 %32 iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement, Front Facing Camera and Sensor Assembly: passo 23, imagem 2 %32
    • Use the tip of a spudger to gently pry up the sensor cable assembly from its recess in the display assembly.
    • The cable is held in place with a mild adhesive.
  24. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 24, imagem 1 %32 iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 24, imagem 2 %32
    • Pry the microphone portion of the front-facing camera and sensor cables from the display assembly.
  25. iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement: passo 25, imagem 1 %32
    • Remove the front-facing camera and sensor cable assembly off the display assembly.
    • Replacement assemblies may or may not come with the speaker mesh already attached. If it's missing, save your old one and re-use it. You can separate it with some heat from a hair dryer and gentle prying or pulling with tweezers.
Conclusão
127 outras pessoas executaram este guia.
13Comentários do guia
My front microphone had completely stopped working exactly a week out of warranty. I replaced the front assembly with a new one from Fixit and afterwards it still did not work. Then I realized the microphone did pick up very soft sound if I shouted directly into it. I eventually repeated the entire disassembly and found a very thin yellow film glued to the microphone grill which had been muffling 97% of the sound. After peeling this off my microphone is working perfectly! I did not notice this on the microphone the first time and assume it was the backing for the self adhesive. Make sure you remove this - it is not obvious to spot!
Anthony Berkow - Responder
ave did wrongSo I replaced my iphone 6 plus screen and after i was done my front camera and my earpiece was no longer working. Any advice on what i might have did wrong ? I have another iphone plus to replace the screen and im a little skeptical now. =\
brian - Responder
Fantastic instructions! fixed my problem first time. Just be patient and try not to touch anything to roughly. Thanks for the tip from a previous comment saying to remove the yellow piece of film over the microphone. This saved me a lot of hassle. Thanks
Glad to have siri, dictation, sound in videos and hansfree calls back :)
lloyd - Responder
hi could i ask one qustion my iphone 6pluse not working after fall i change new sensore bu tnot working how to fix please conect to me
peth - Responder
Is the picture quality the same
QuentaviouS - Responder
Comentar
Visualizações:
Últimas 24 horas: 14
Últimos 7 dias: 134
Últimos 30 dias: 999
Ao todo: 127,137
