Ir para o conteúdo principal
iPhone 5 Lightning Connector and Headphone Jack Replacement
O que você precisa
Vídeo de Apresentação
  1. iPhone 5 Lightning Connector and Headphone Jack Replacement, Taping the display glass: passo 1, imagem 1 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement, Taping the display glass: passo 1, imagem 2 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement, Taping the display glass: passo 1, imagem 3 %32
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  2. iPhone 5 Lightning Connector and Headphone Jack Replacement, Remove the Pentalobe screws: passo 2, imagem 1 %32
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
  3. iPhone 5 Lightning Connector and Headphone Jack Replacement, How to prevent display separation: passo 3, imagem 1 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement, How to prevent display separation: passo 3, imagem 2 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement, How to prevent display separation: passo 3, imagem 3 %32
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
  4. iPhone 5 Lightning Connector and Headphone Jack Replacement, Anti-Clamp instructions: passo 4, imagem 1 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement, Anti-Clamp instructions: passo 4, imagem 2 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement, Anti-Clamp instructions: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 5, imagem 1 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 5, imagem 2 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 5, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. iPhone 5 Lightning Connector and Headphone Jack Replacement, Manual Opening Procedure: passo 6, imagem 1 %32
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
    • If you're opening an iPhone with cracked glass, neatly lay a couple strips of packing tape across the front and squeeze out as many bubbles as you can. This will give the suction cup a surface to grab, and minimize the spread of broken glass.
  7. iPhone 5 Lightning Connector and Headphone Jack Replacement, Start lifting the front panel assembly: passo 7, imagem 1 %32
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The screen is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the screen, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  8. iPhone 5 Lightning Connector and Headphone Jack Replacement, Detaching the front panel side clips: passo 8, imagem 1 %32
    • Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
  9. iPhone 5 Lightning Connector and Headphone Jack Replacement, Opening up the phone: passo 9, imagem 1 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement, Opening up the phone: passo 9, imagem 2 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement, Opening up the phone: passo 9, imagem 3 %32
    • Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone.
    • Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  10. iPhone 5 Lightning Connector and Headphone Jack Replacement, Removing the battery connector bracket screws: passo 10, imagem 1 %32
    • Remove the following two screws securing the metal battery connector bracket to the logic board:
    • One 1.8 mm Phillips screw
    • One 1.6 mm Phillips screw
  11. iPhone 5 Lightning Connector and Headphone Jack Replacement, Removing the battery connector bracket: passo 11, imagem 1 %32
    • Remove the metal battery connector bracket from the iPhone.
  12. iPhone 5 Lightning Connector and Headphone Jack Replacement, Disconnecting the battery connector: passo 12, imagem 1 %32
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
  13. iPhone 5 Lightning Connector and Headphone Jack Replacement, Removing the front panel assembly cable bracket screws: passo 13, imagem 1 %32
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.2 mm Phillips screws
    • This screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing, and make sure it gets back into the right place—a magnetized screw may interfere with the compass.
  14. iPhone 5 Lightning Connector and Headphone Jack Replacement, Removing the front panel assembly cable bracket: passo 14, imagem 1 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement, Removing the front panel assembly cable bracket: passo 14, imagem 2 %32
    • Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone.
    • During reassembly, clip the left-hand hooks under the logic board and lower the bracket towards the outside of the phone.
  15. iPhone 5 Lightning Connector and Headphone Jack Replacement, Disconnecting the front panel assembly cables: passo 15, imagem 1 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement, Disconnecting the front panel assembly cables: passo 15, imagem 2 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement, Disconnecting the front panel assembly cables: passo 15, imagem 3 %32
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a plastic opening tool or a fingernail to disconnect the three front panel assembly cables:
    • Front-facing camera and sensor cable
    • LCD cable
    • Digitizer cable
    • When reassembling your phone, the LCD cable may pop off the connector. This can cause white lines, or nothing at all to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
  16. iPhone 5 Lightning Connector and Headphone Jack Replacement, Separating front panel assembly and rear case: passo 16, imagem 1 %32
    • Remove the front panel assembly from the rear case.
  17. iPhone 5 Lightning Connector and Headphone Jack Replacement, Speaker Enclosure: passo 17, imagem 1 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement, Speaker Enclosure: passo 17, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the antenna cable from the logic board.
  18. iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 18, imagem 1 %32
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the following screws securing the speaker enclosure to the rear case:
    • One 2.5 mm Phillips screw
    • One 1.5 mm Phillips screw
    • One 2.7 mm standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  19. iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 19, imagem 1 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 19, imagem 2 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 19, imagem 3 %32
    • Slide the point of a spudger underneath the spring contact flex cable below the battery and gently loosen it from the speaker enclosure.
  20. iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 20, imagem 1 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 20, imagem 2 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 20, imagem 3 %32
    • Use the flat end of a spudger to pry up and loosen the speaker enclosure from the rear case.
    • Pull the speaker enclosure out of its recess.
    • During reinstallation, be sure to slide the speaker enclosure underneath this metal washer.
  21. iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 21, imagem 1 %32
    • Remove the small double-sided metal washer on the speaker enclosure and transfer it to the replacement part.
  22. iPhone 5 Lightning Connector and Headphone Jack Replacement, Lightning Connector and Headphone Jack: passo 22, imagem 1 %32
    • Remove the following screws securing the Lightning connector assembly to the rear case:
    • One 2.9 mm Phillips screw
    • During re-installation, make sure that the headphone jack's plastic protrusion lies above the metal washer.
    • Two 3.3 mm Phillips screws
  23. iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 23, imagem 1 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 23, imagem 2 %32
    • Use the opening tool to pry up and disconnect the Lightning connector cable connector from its socket on the logic board.
  24. iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 24, imagem 1 %32
    • Flip the phone face up, heat an iOpener, and apply it to the right edge of the phone for a minute.
  25. iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 25, imagem 1 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 25, imagem 2 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 25, imagem 3 %32
    • Slide an opening pick underneath the Lightning connector flex cable to loosen it from the logic board and the rear case.
  26. iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 26, imagem 1 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 26, imagem 2 %32
    • Use the flat end of a spudger to loosen the rest of the Lightning connector assembly from the rear case.
  27. iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 27, imagem 1 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 27, imagem 2 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 27, imagem 3 %32
    • Angle the Lightning connector assembly and pull it out of its recess.
    • Remove the four metal washers and set them aside for reassembly.
    • Before reassembly, use the opening tool or the flat end of a spudger to remove all adhesive residue from the rear case. You can use high-concentration isopropyl alcohol to help with the stubborn spots.
  28. iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 28, imagem 1 %32 iPhone 5 Lightning Connector and Headphone Jack Replacement: passo 28, imagem 2 %32
    • Use tweezers to gently pull and remove the rubber microphone sleeve off of the microphone. Transfer the sleeve onto the replacement part.
Conclusão
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our iPhone 5 Answers community for troubleshooting help.
512 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
322.865 Reputação
Autoria de 793 guias
Equipe
iFixit Membro de iFixit
Staff
124 Membros
Autoria de 24.162 guias
67Comentários do guia
Just a quick note that if you're doing this teardown because your iPhone 5 isn't charging unless you apply some force to the Lightning cable, the problem may simply be some lint or other crud in the Lightning port. Blow some compressed air in there before you disassemble your iPhone and see if it solves the problem - it did for me.
Adam Engst - Responder Compartilhar
ifixed my i5 by cleaning the port too (was just about to buy the kit!). I found a paper clip done the job perfectly.
Cheers, Adam Engst.
Abdul Ali - Compartilhar
Also found dirt was the only fault with a number of 5's.
Gary - Compartilhar
Well I bought the replacement first and then realized about the dirt. I removed the dirt and it is now working again. I guess after 2 years the thing accumulates quite a bit of dust.
esleep - Compartilhar
THANK YOU for your comment, Adam, and the others that took the time to confirm it worked for them. Thankfully I read it before attempting this repair on my iPhone 5S. It took only 10 seconds with a very skinny (<1 mm) screwdriver, scraping the deep edge of the port, and I pulled out a wad of pocket lint that was about the size of a pea when uncompressed. A paperclip would have done the job. Charger works perfectly now.
Erin S - Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 52
Últimos 7 dias: 769
Últimos 30 dias: 4,521
Ao todo: 711,384
