Ir para o conteúdo principal
iPhone 15 Pro Max Screen Opening
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
  1. iPhone 15 Pro Max Screen Opening, Secure the back glass: passo 1, imagem 1 %32 iPhone 15 Pro Max Screen Opening, Secure the back glass: passo 1, imagem 2 %32 iPhone 15 Pro Max Screen Opening, Secure the back glass: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next four steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down four steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • The Anti-Clamp applies suction to both the screen and the back glass. To open the screen, you need to secure the back glass with tape. You can also check out the full instructions on how to use this tape.
    • Cut two strips of tape, apply them along the long edges of the phone, and fold them over the back glass to secure it.
  2. iPhone 15 Pro Max Screen Opening, Secure an Anti-Clamp: passo 2, imagem 1 %32 iPhone 15 Pro Max Screen Opening, Secure an Anti-Clamp: passo 2, imagem 2 %32 iPhone 15 Pro Max Screen Opening, Secure an Anti-Clamp: passo 2, imagem 3 %32
    • Pull the Anti-Clamp's blue handle backward to unlock the arms.
    • With the screen facing up, slide the arms over the left edge of your phone, with one suction cup on the screen and the other on the back glass. Center the suction cups near the bottom edge.
    • Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
    • Squeeze the cups together to create suction.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  3. iPhone 15 Pro Max Screen Opening, Create a gap under the screen: passo 3, imagem 1 %32 iPhone 15 Pro Max Screen Opening, Create a gap under the screen: passo 3, imagem 2 %32 iPhone 15 Pro Max Screen Opening, Create a gap under the screen: passo 3, imagem 3 %32
    • Pull the blue handle forward to lock the arms.
    • Turn the handle one full turn (360 degrees) or until the cups start to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they tend to slip, remove the Anti-Clamp and apply tape for the cups to stick to.
    • If you don't have tape, you may use your hands to clean the suction cups and warm them up to help them stick.
  4. iPhone 15 Pro Max Screen Opening, Insert an opening pick: passo 4, imagem 1 %32 iPhone 15 Pro Max Screen Opening, Insert an opening pick: passo 4, imagem 2 %32 iPhone 15 Pro Max Screen Opening, Insert an opening pick: passo 4, imagem 3 %32
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    • Wait up to a minute for the adhesive to separate and a gap to form between the screen and the frame.
    • If a gap doesn't appear after one minute, apply more heat and rotate the handle a quarter turn. Let the Anti-Clamp and time do the work for you.
    • Insert an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  5. iPhone 15 Pro Max Screen Opening, Heat the bottom edge: passo 5, imagem 1 %32
  6. iPhone 15 Pro Max Screen Opening, Insert an opening pick: passo 6, imagem 1 %32 iPhone 15 Pro Max Screen Opening, Insert an opening pick: passo 6, imagem 2 %32 iPhone 15 Pro Max Screen Opening, Insert an opening pick: passo 6, imagem 3 %32
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Pro Max Screen Opening, Screen information: passo 7, imagem 1 %32
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
  8. iPhone 15 Pro Max Screen Opening, Separate the bottom edge adhesive: passo 8, imagem 1 %32 iPhone 15 Pro Max Screen Opening, Separate the bottom edge adhesive: passo 8, imagem 2 %32 iPhone 15 Pro Max Screen Opening, Separate the bottom edge adhesive: passo 8, imagem 3 %32
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Pro Max Screen Opening, Heat the right edge: passo 9, imagem 1 %32
    • Heat the right edge of the screen until it's hot to the touch.
  10. iPhone 15 Pro Max Screen Opening, Position the opening pick: passo 10, imagem 1 %32 iPhone 15 Pro Max Screen Opening, Position the opening pick: passo 10, imagem 2 %32 iPhone 15 Pro Max Screen Opening, Position the opening pick: passo 10, imagem 3 %32
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
  11. iPhone 15 Pro Max Screen Opening, Release the right clip: passo 11, imagem 1 %32 iPhone 15 Pro Max Screen Opening, Release the right clip: passo 11, imagem 2 %32 iPhone 15 Pro Max Screen Opening, Release the right clip: passo 11, imagem 3 %32
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
  12. iPhone 15 Pro Max Screen Opening, Separate the right edge adhesive: passo 12, imagem 1 %32 iPhone 15 Pro Max Screen Opening, Separate the right edge adhesive: passo 12, imagem 2 %32 iPhone 15 Pro Max Screen Opening, Separate the right edge adhesive: passo 12, imagem 3 %32
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
  13. iPhone 15 Pro Max Screen Opening, Heat the top edge: passo 13, imagem 1 %32
    • Heat the top edge of the screen until it's hot to the touch.
  14. iPhone 15 Pro Max Screen Opening, Separate the top edge adhesive: passo 14, imagem 1 %32 iPhone 15 Pro Max Screen Opening, Separate the top edge adhesive: passo 14, imagem 2 %32 iPhone 15 Pro Max Screen Opening, Separate the top edge adhesive: passo 14, imagem 3 %32
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
  15. iPhone 15 Pro Max Screen Opening, Heat the left edge: passo 15, imagem 1 %32
    • Heat the left edge of the screen until it's hot to the touch.
  16. iPhone 15 Pro Max Screen Opening, Separate the left edge adhesive: passo 16, imagem 1 %32 iPhone 15 Pro Max Screen Opening, Separate the left edge adhesive: passo 16, imagem 2 %32 iPhone 15 Pro Max Screen Opening, Separate the left edge adhesive: passo 16, imagem 3 %32
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
Conclusão
Clay Eickemeyer
Membro desde: 09/19/22
81.013 Reputação
Autoria de 455 guias
Equipe
Guide Team Membro de Guide Team
Staff
Membros da 9
Autoria de 11.335 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 43
