Ir para o conteúdo principal
iPhone 14 Plus Taptic Engine Replacement
O que você precisa
  1. iPhone 14 Plus Taptic Engine Replacement, Remove the pentalobe screws: passo 1, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Remove the pentalobe screws: passo 1, imagem 2 %32
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
  2. iPhone 14 Plus Taptic Engine Replacement, Mark your opening picks: passo 2, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Mark your opening picks: passo 2, imagem 2 %32 iPhone 14 Plus Taptic Engine Replacement, Mark your opening picks: passo 2, imagem 3 %32
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  3. iPhone 14 Plus Taptic Engine Replacement, Tape over any cracks: passo 3, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Tape over any cracks: passo 3, imagem 2 %32
    • If your iPhone has a cracked rear glass, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
    • If all else fails, you can superglue the suction cup to the rear glass.
  4. iPhone 14 Plus Taptic Engine Replacement, Heat the bottom edge: passo 4, imagem 1 %32
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  5. iPhone 14 Plus Taptic Engine Replacement, Insert an opening pick: passo 5, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Insert an opening pick: passo 5, imagem 2 %32 iPhone 14 Plus Taptic Engine Replacement, Insert an opening pick: passo 5, imagem 3 %32
    • Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
    • Insert an opening pick into the gap.
    • The adhesive holding the rear glass in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the rear glass up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
  6. iPhone 14 Plus Taptic Engine Replacement, Heat the left edge: passo 6, imagem 1 %32
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
  7. iPhone 14 Plus Taptic Engine Replacement, Slice the left edge adhesive: passo 7, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Slice the left edge adhesive: passo 7, imagem 2 %32 iPhone 14 Plus Taptic Engine Replacement, Slice the left edge adhesive: passo 7, imagem 3 %32
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  8. iPhone 14 Plus Taptic Engine Replacement, Heat the right edge: passo 8, imagem 1 %32
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the rear glass is slightly too hot to touch.
  9. iPhone 14 Plus Taptic Engine Replacement, Screen information: passo 9, imagem 1 %32
    • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
  10. iPhone 14 Plus Taptic Engine Replacement, Slice the right edge adhesive: passo 10, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Slice the right edge adhesive: passo 10, imagem 2 %32 iPhone 14 Plus Taptic Engine Replacement, Slice the right edge adhesive: passo 10, imagem 3 %32
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the charging coil cable.
  11. iPhone 14 Plus Taptic Engine Replacement, Heat the top edge: passo 11, imagem 1 %32
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
  12. iPhone 14 Plus Taptic Engine Replacement, Slice the top edge adhesive: passo 12, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Slice the top edge adhesive: passo 12, imagem 2 %32 iPhone 14 Plus Taptic Engine Replacement, Slice the top edge adhesive: passo 12, imagem 3 %32
    • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
  13. iPhone 14 Plus Taptic Engine Replacement: passo 13, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement: passo 13, imagem 2 %32 iPhone 14 Plus Taptic Engine Replacement: passo 13, imagem 3 %32
    • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and halfway across the top edge.
    • Don't insert the pick more than 3 mm, as you may damage or smear the camera array.
    • Don't try to fully separate the rear glass yet, as there's a fragile ribbon cable connecting it to the iPhone's logic board.
  14. iPhone 14 Plus Taptic Engine Replacement, Open the iPhone: passo 14, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Open the iPhone: passo 14, imagem 2 %32 iPhone 14 Plus Taptic Engine Replacement, Open the iPhone: passo 14, imagem 3 %32
    • Remove your suction handle from the rear glass.
    • Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
    • Be careful not to strain the short charging coil flex cable.
    • Lean the rear glass against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
    • During reassembly, lay the rear glass in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the rear glass and make sure they aren't bent.
  15. iPhone 14 Plus Taptic Engine Replacement, Unfasten the battery connector cover screws: passo 15, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $16.96
    • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  16. iPhone 14 Plus Taptic Engine Replacement, Remove the battery connector cover: passo 16, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Remove the battery connector cover: passo 16, imagem 2 %32 iPhone 14 Plus Taptic Engine Replacement, Remove the battery connector cover: passo 16, imagem 3 %32
    • Grasp the battery connector cover with a pair of tweezers and slide it upwards (towards the A15 print) to unlatch the top hook.
    • Remove the battery connector cover.
  17. iPhone 14 Plus Taptic Engine Replacement, Disconnect the battery: passo 17, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Disconnect the battery: passo 17, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  18. iPhone 14 Plus Taptic Engine Replacement, Unfasten the charging coil connector cover: passo 18, imagem 1 %32
    • Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
  19. iPhone 14 Plus Taptic Engine Replacement, Remove the charging coil connector bracket: passo 19, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Remove the charging coil connector bracket: passo 19, imagem 2 %32
    • Use a pair of tweezers to remove the charging coil connector cover.
  20. iPhone 14 Plus Taptic Engine Replacement, Disconnect the charging coil: passo 20, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Disconnect the charging coil: passo 20, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
  21. iPhone 14 Plus Taptic Engine Replacement, Remove the rear glass assembly: passo 21, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Remove the rear glass assembly: passo 21, imagem 2 %32
    • Remove the rear glass assembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the rear glass adhesives.
  22. iPhone 14 Plus Taptic Engine Replacement, Remove the Taptic Engine screws: passo 22, imagem 1 %32
    • Use a Phillips screwdriver to remove the four screws securing the Taptic Engine.
    • Two 1.7 mm-long screws
    • One 1.4 mm-long screw
    • One 1.8 mm-long screw
  23. iPhone 14 Plus Taptic Engine Replacement, Remove the Taptic Engine connector bracket: passo 23, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Remove the Taptic Engine connector bracket: passo 23, imagem 2 %32
    • Use a pair of tweezers to remove the Taptic Engine connector bracket.
  24. iPhone 14 Plus Taptic Engine Replacement, Disconnect the Taptic Engine: passo 24, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Disconnect the Taptic Engine: passo 24, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the Taptic Engine by prying the connector straight up from its socket.
  25. iPhone 14 Plus Taptic Engine Replacement, Remove the standoff screw: passo 25, imagem 1 %32
    Standoff Screwdriver for iPhones
    $5.49
    • Use a standoff driver to remove the 3.1 mm-long standoff screw.
    • Standoff screws are best removed using a dedicated standoff driver or driver bit. In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  26. iPhone 14 Plus Taptic Engine Replacement, Remove the Taptic Engine: passo 26, imagem 1 %32 iPhone 14 Plus Taptic Engine Replacement, Remove the Taptic Engine: passo 26, imagem 2 %32
    • Use a pair of tweezers or your fingers to remove the Taptic Engine.
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Dominik Schnabelrauch
Membro desde: 11/23/16
246.266 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.608 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 40
Últimos 30 dias: 117
Ao todo: 2,839
