Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
iPad Pro 10.5" Opening Procedure
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iPad Pro 10.5" Opening Procedure, Display Assembly: passo 1, imagem 1 %32 iPad Pro 10.5" Opening Procedure, Display Assembly: passo 1, imagem 2 %32
    • Strong adhesive holds the screen in place. In order to separate it, you'll first need to heat and soften the adhesive using an iOpener, hair dryer, or heat gun.
    • You may need to reapply heat repeatedly throughout this process to prevent the adhesive from cooling and hardening.
    • Prepare an iOpener and place it on the bottom edge of the iPad's screen for about two minutes.
  2. iPad Pro 10.5" Opening Procedure: passo 2, imagem 1 %32
    • If your iPad's screen is badly cracked, wear skin and eye protection. Cover the screen with a smooth layer of clear packing tape to contain glass shards and help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and fold it into a handle.
    • Place a suction cup next to the iPad's home button and press down to create a seal.
    • To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
    • Firmly pull up on the suction cup to to create a small gap between the front panel and the rear case.
    • Don't pull too hard, or you may shatter the glass. If necessary, apply more heat to further soften the adhesive.
    • Once you've opened a sufficient gap, insert an opening pick into the gap.
  3. iPad Pro 10.5" Opening Procedure: passo 3, imagem 1 %32 iPad Pro 10.5" Opening Procedure: passo 3, imagem 2 %32
    • Slice through the adhesive under the screen by sliding the pick along the edge of the display, towards the bottom left corner.
    • Leave the pick in place temporarily to prevent the adhesive from re-sealing.
  4. iPad Pro 10.5" Opening Procedure: passo 4, imagem 1 %32 iPad Pro 10.5" Opening Procedure: passo 4, imagem 2 %32 iPad Pro 10.5" Opening Procedure: passo 4, imagem 3 %32
    • Apply heat to the left edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
    • If necessary, re-heat your iOpener for a few seconds or until it's a bit too hot to touch. Be careful not to overheat the iOpener, or it may burst.
    • Insert a second opening pick at the bottom left corner of the iPad.
    • Slide the second opening pick along the left side of the display to separate the adhesive underneath.
    • Leave the opening pick inserted near the top left corner of the iPad to prevent the adhesive from re-sealing.
  5. iPad Pro 10.5" Opening Procedure: passo 5, imagem 1 %32
    • Apply heat to the top edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
  6. iPad Pro 10.5" Opening Procedure: passo 6, imagem 1 %32 iPad Pro 10.5" Opening Procedure: passo 6, imagem 2 %32 iPad Pro 10.5" Opening Procedure: passo 6, imagem 3 %32
    • Insert a third opening pick at the top left corner of the iPad.
    • Use the opening pick to cut the adhesive under the top edge of the iPad by sliding it to the top right corner.
    • The front-facing camera is located right in the center of the iPad's top edge and can be damaged if the pick is inserted too far. Only insert the tip of the opening pick when cutting near the camera.
  7. iPad Pro 10.5" Opening Procedure: passo 7, imagem 1 %32 iPad Pro 10.5" Opening Procedure: passo 7, imagem 2 %32 iPad Pro 10.5" Opening Procedure: passo 7, imagem 3 %32
    • Apply heat to the final, right edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
    • Insert a fourth opening pick at the top right corner of the iPad.
    • Slide the opening pick down to the bottom right corner to cut the adhesive.
    • Slide the opening pick around the bottom right corner—pausing to apply more heat if needed—and cut the remaining adhesive on the bottom edge, but stop before you reach the home button.
  8. iPad Pro 10.5" Opening Procedure: passo 8, imagem 1 %32 iPad Pro 10.5" Opening Procedure: passo 8, imagem 2 %32
    • Insert a fifth opening pick at the top of the iPad near (but not directly on) the front-facing camera.
    • Gently twist the pick to separate the display assembly from the iPad.
    • Don't try to remove the display all the way yet! It is still connected to the iPad's motherboard.
    • If needed, apply more heat and/or cut any remaining adhesive that prevents the display from separating.
  9. iPad Pro 10.5" Opening Procedure: passo 9, imagem 1 %32 iPad Pro 10.5" Opening Procedure: passo 9, imagem 2 %32 iPad Pro 10.5" Opening Procedure: passo 9, imagem 3 %32
    • Lift the display assembly from its top edge and carefully slide it up (towards the front-facing camera and headphone jack), until the screw that secures the battery power connector is revealed at the bottom.
    • Don't lift the display more than 70° or you may damage the attached ribbon cables.
  10. iPad Pro 10.5" Opening Procedure: passo 10, imagem 1 %32 iPad Pro 10.5" Opening Procedure: passo 10, imagem 2 %32
    • Remove the 1.9 mm Phillips screw that secures the battery power connector.
    • Take extreme care when you insert the battery blocker. Insert it gently and straight in the direction of the logic board. Do not twist or swing the pick side to side.
    • To disconnect the battery, slide one prong of a Battery Blocker or the tip of an opening pick under the battery power connector to ensure the power circuit is interrupted.
  11. iPad Pro 10.5" Opening Procedure: passo 11, imagem 1 %32 iPad Pro 10.5" Opening Procedure: passo 11, imagem 2 %32 iPad Pro 10.5" Opening Procedure: passo 11, imagem 3 %32
    • Slowly lift the display from its top edge, being careful not to strain the attached ribbon cables.
    • Remove the two 1.3 mm Phillips screws securing the display connector cover bracket.
    • You may need to angle the driver slightly in order to avoid straining the ribbon cables.
    • Remove the display connector cover bracket.
  12. iPad Pro 10.5" Opening Procedure: passo 12, imagem 1 %32 iPad Pro 10.5" Opening Procedure: passo 12, imagem 2 %32 iPad Pro 10.5" Opening Procedure: passo 12, imagem 3 %32
    • Use a spudger to disconnect the two visible display flex connectors by gently prying them straight up from their sockets.
  13. iPad Pro 10.5" Opening Procedure: passo 13, imagem 1 %32 iPad Pro 10.5" Opening Procedure: passo 13, imagem 2 %32 iPad Pro 10.5" Opening Procedure: passo 13, imagem 3 %32
    • Underneath, you'll find two additional display cable connectors.
    • Use your spudger to gently pry them up and disconnect them.
  14. iPad Pro 10.5" Opening Procedure: passo 14, imagem 1 %32
    • Remove the display assembly.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • If you plan to reinstall your existing display, remove any remaining adhesive from the back and clean the adhered areas with isopropyl alcohol.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
Conclusão
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
To reassemble your device, follow this guide in reverse order.
Dominik Schnabelrauch
Membro desde: 11/23/16
203.362 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 439
