Ir para o conteúdo principal
iMac Intel 27" Retina 5K Display Display Replacement
O que você precisa
  1. iMac Intel 27" Retina 5K Display Display Replacement, Display: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    iMac Intel 27" Cardboard Service Wedge
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
    • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
    Pergunte ao FixBot
    Comentar
  2. iMac Intel 27" Retina 5K Display Display Replacement: passo 2, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 2, imagem 2 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 2, imagem 3 %32
    • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage.
    Pergunte ao FixBot
    Comentar
  3. iMac Intel 27" Retina 5K Display Display Replacement: passo 3, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 3, imagem 2 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 3, imagem 3 %32
    • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
    • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
    Pergunte ao FixBot
    Comentar
  4. iMac Intel 27" Retina 5K Display Display Replacement: passo 4, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 4, imagem 2 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 4, imagem 3 %32
    • Continue wheeling the tool up around the top left corner.
    Pergunte ao FixBot
    Comentar
  5. iMac Intel 27" Retina 5K Display Display Replacement: passo 5, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 5, imagem 2 %32
    • Cut the adhesive along the top left of the display.
    Pergunte ao FixBot
    Comentar
  6. iMac Intel 27" Retina 5K Display Display Replacement: passo 6, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 6, imagem 2 %32
    • Continue along the top of the display.
    • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
    Pergunte ao FixBot
    Comentar
  7. iMac Intel 27" Retina 5K Display Display Replacement: passo 7, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 7, imagem 2 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 7, imagem 3 %32
    • Push the tool around the top right corner of the display.
    Pergunte ao FixBot
    Comentar
  8. iMac Intel 27" Retina 5K Display Display Replacement: passo 8, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 8, imagem 2 %32
    • Wheel the tool down along the right side of the display.
    Pergunte ao FixBot
    Comentar
  9. iMac Intel 27" Retina 5K Display Display Replacement: passo 9, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 9, imagem 2 %32
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
    Pergunte ao FixBot
    Comentar
  10. iMac Intel 27" Retina 5K Display Display Replacement: passo 10, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 10, imagem 2 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 10, imagem 3 %32
    Plastic Cards
    $2.99
    • While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
    • Be careful not to insert it more than 3/8" (9.5 mm), or you may damage internal components.
    Pergunte ao FixBot
    Comentar
  11. iMac Intel 27" Retina 5K Display Display Replacement: passo 11, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 11, imagem 2 %32
    • Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner.
    • Using too much force will crack the glass. Work carefully, and don't try to create a gap any larger than about 1/4" (6 mm).
    Pergunte ao FixBot
    Comentar
  12. iMac Intel 27" Retina 5K Display Display Replacement: passo 12, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 12, imagem 2 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 12, imagem 3 %32
    • Be sure to stop cutting before the iSight camera in this step, or you may damage it.
    • Slide the card toward the center of the display, to cut any remaining adhesive.
    Pergunte ao FixBot
    Comentar
  13. iMac Intel 27" Retina 5K Display Display Replacement: passo 13, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 13, imagem 2 %32
    • Put the card into the corner again and let it stay there to keep the adhesive from resettling.
    Pergunte ao FixBot
    Comentar
  14. iMac Intel 27" Retina 5K Display Display Replacement: passo 14, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 14, imagem 2 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 14, imagem 3 %32
    • Insert a second card into the gap between the display and frame in the top left corner.
    Pergunte ao FixBot
    Comentar
  15. iMac Intel 27" Retina 5K Display Display Replacement: passo 15, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 15, imagem 2 %32
    • Gently twist the card, slightly increasing the space between the display and frame.
    • As with the other side, move slowly to allow the adhesive to break, and be careful not to over-stress the display glass.
    Pergunte ao FixBot
    Comentar
  16. iMac Intel 27" Retina 5K Display Display Replacement: passo 16, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 16, imagem 2 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 16, imagem 3 %32
    • Slide the plastic card toward the center, again stopping just before the iSight camera.
    Pergunte ao FixBot
    Comentar
  17. iMac Intel 27" Retina 5K Display Display Replacement: passo 17, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 17, imagem 2 %32
    • Insert the card back into the top left corner.
    Pergunte ao FixBot
    Comentar
  18. iMac Intel 27" Retina 5K Display Display Replacement: passo 18, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 18, imagem 2 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 18, imagem 3 %32
    • Only lift the display a few inches—it is still attached to the iMac by data and power cables.
    • With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
    • Begin to lift the top of the display up from the frame.
    Pergunte ao FixBot
    Comentar
  19. iMac Intel 27" Retina 5K Display Display Replacement: passo 19, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 19, imagem 2 %32
    • While holding the display up with one hand, use the other to unplug the display power cable.
    • Lift the display up enough to have easy access to the connections, but not so much that you stretch the cables and stress their connections (about 8").
    Pergunte ao FixBot
    Comentar
  20. iMac Intel 27" Retina 5K Display Display Replacement: passo 20, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 20, imagem 2 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 20, imagem 3 %32
    • Flip up the metal retaining bracket on the display data cable.
    • Disconnect the display data cable.
    • This is a delicate connection that can easily be broken. Be sure to pull the display data cable connector straight out of its socket, toward the top of the iMac.
    Pergunte ao FixBot
    Comentar
  21. iMac Intel 27" Retina 5K Display Display Replacement: passo 21, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 21, imagem 2 %32
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
    • Remove as much of the adhesive as possible by grabbing it at the outer edges, and then pulling or rolling it towards the middle.
    Pergunte ao FixBot
    Comentar
  22. iMac Intel 27" Retina 5K Display Display Replacement: passo 22, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 22, imagem 2 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 22, imagem 3 %32
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
    Pergunte ao FixBot
    Comentar
  23. iMac Intel 27" Retina 5K Display Display Replacement: passo 23, imagem 1 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 23, imagem 2 %32 iMac Intel 27" Retina 5K Display Display Replacement: passo 23, imagem 3 %32
    • Be very careful handling the display—it's big, heavy, and made of glass. The display has fragile edges. Avoid lifting the display by the corners.
    • Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
    • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide when your repair is complete to replace the adhesive strips that secure the display to the rear enclosure.
    Pergunte ao FixBot
    Comentar
  24. iMac Intel 27" Retina 5K Display Display Replacement: passo 24, imagem 1 %32
    • If you are replacing the display panel, you may need to transfer additional components from the old panel to the new one. Compare the back of the old display with the replacement display. Note all cables, sensors, and foam cushioning that are missing from the new display.
    • If there is a wire or cable underneath adhesive tape, always pull the tape off first.
    • If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull directly on the delicate connectors.
    • Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
56 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
477.674 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 27.624 guias
27Comentários do guia
If you cut around the display well and take your time to roll back and forth (using the iFixit roller opener tool), especially around the corners, you don't actually need to use any cards (Steps 9 - 17) to get the screen to come free of the body. On the top edge left and right, take each end of the screen gently and pry free with your fingers - GENTLY - and you will hear the remaining tape separating along the sides. Take care NOT to flex the screen as you do so.
If you are removing a cracked screen (as I was), be super careful to pry and swing the display EVENLY up from the body - this is an item of utmost importance, whether you use cards or not to get the last of the adhesive to release.
drmacnut - Responder Compartilhar
Finally, with the power and data cables disconnected and the display held up at around 80º, you will find that the adhesive along the bottom edge of the display assembly will take quite some work to free. As the guide says, you can use a plastic card; but I found it necessary to use a metal spuger (carefully so as not to touch the power supply board of course!) in order to free the lower adhesive and remove the display.
Overall, take your time and focus on "being one with the iMac" as you work, and you will find it quite trivial to remove this 27" retina display.
hello, I'm writing from Italy. I have a problem with the screen of the iMac 27 "5k retina late 2014, purchased the 12-22-2014, I do not know if the warranty covers this type of defect within two years. There are spots in the lower left, appear as sagging, I think it's the dust, but I assure you that the environment is clean with no smoke or whatever. Obviously the spots are inside, how can I fix it, other news of these spots? I have to completely change the display or can separate the glass from the monitor LED?
Many thanks
Enzo
Enzo - Responder Compartilhar
this should be covered by warranty. call applecare.
vireshkj - Responder Compartilhar
Hello,
Any Update? Mine has the same issue and it is out of warranty.
Would an air blower do the trick past point 17/18?
Homoud Al-Jalahma - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 133
Últimos 30 dias: 668
Ao todo: 200,326
