Ir para o conteúdo principal
iMac 2011 SSD Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iMac 2011 SSD Replacement, Replace the hard drive with an SSD: passo 1, imagem 1 %32 iMac 2011 SSD Replacement, Replace the hard drive with an SSD: passo 1, imagem 2 %32 iMac 2011 SSD Replacement, Replace the hard drive with an SSD: passo 1, imagem 3 %32
    • Follow the next steps if you are replacing your hard drive with an SSD kit.
    • If your SSD enclosure looks like the first image, follow this guide instead.
    • Line up the SSD connectors with the metal enclosure's sockets.
    • Press the drive against the enclosure sockets until the SSD is firmly seated.
    • The SSD connects with the enclosure in only one direction. If the connectors don't line up, rotate the SSD and try again.
  2. iMac 2011 SSD Replacement: passo 2, imagem 1 %32 iMac 2011 SSD Replacement: passo 2, imagem 2 %32 iMac 2011 SSD Replacement: passo 2, imagem 3 %32
    • Use a Phillips screwdriver to install the four silver screws (two on each side) along the edges of the SSD to secure it to the enclosure.
  3. iMac 2011 SSD Replacement: passo 3, imagem 1 %32 iMac 2011 SSD Replacement: passo 3, imagem 2 %32
    • Plug the included sensor-enabled SATA power cable into the enclosure's port.
    • The cable is keyed to connect in only one orientation. If you can't connect the cable, rotate it 180° and try again.
  4. iMac 2011 SSD Replacement: passo 4, imagem 1 %32 iMac 2011 SSD Replacement: passo 4, imagem 2 %32 iMac 2011 SSD Replacement: passo 4, imagem 3 %32
    • Peel the white liner off the back of the small temperature sensor board in order to expose the adhesive.
    • Adhere the temperature sensor board to an exposed, metal surface of the SSD, close to the SATA connector.
    • Fold the excess temperature sensor wires so that they are out of the way while you install the enclosure.
  5. iMac 2011 SSD Replacement: passo 5, imagem 1 %32 iMac 2011 SSD Replacement: passo 5, imagem 2 %32
    • Use a T8 driver to install the mounting pins from the old hard drive onto the sides of the enclosure.
  6. iMac 2011 SSD Replacement: passo 6, imagem 1 %32 iMac 2011 SSD Replacement: passo 6, imagem 2 %32
    • Attach any mounting brackets removed from the old hard drive onto the enclosure.
  7. iMac 2011 SSD Replacement: passo 7, imagem 1 %32 iMac 2011 SSD Replacement: passo 7, imagem 2 %32
    • Connect the iMac's SATA power cable to the other end of the new sensor-enabled SATA cable.
  8. iMac 2011 SSD Replacement: passo 8, imagem 1 %32 iMac 2011 SSD Replacement: passo 8, imagem 2 %32
    • Connect the iMac's SATA data cable to the enclosure.
  9. iMac 2011 SSD Replacement: passo 9, imagem 1 %32 iMac 2011 SSD Replacement: passo 9, imagem 2 %32 iMac 2011 SSD Replacement: passo 9, imagem 3 %32
    • The images used in this step come from a 2017 iMac. Your cables may look slightly different, but the procedure remains the same.
    • Slide the SSD enclosure into the space previously occupied by the hard drive.
    • Route the SATA cables so that they will not interfere with any other components.
    • Try to keep the cables free from any sharp bends, and route them such that they are not pinched.
Conclusão
Arthur Shi
Membro desde: 01/03/18
281.997 Reputação
Autoria de 585 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.425 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 9
Últimos 30 dias: 14
Duração total: 769
