Ir para o conteúdo principal
Ajuda
How to Repair Corners of Drywall
Editando passo 1 —
Tipo de Passo:
Arraste para reorganizar
Measure top and bottom of damaged section.
When replacing a corner bead, you must measure at least 1.5 inches from the corner.
Use a straight edge between the the top and bottom and draw a straight-line connecting the marking.
You can even use the putty knife if the damaged section is not too long.
Mark with a pencil, or cut lightly with utility knife.
Use caution when using the utility knife as the blade is very sharp and may cause an injury.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
