Ir para o conteúdo principal
Zerodate T26 RGB LED Replacement
O que você precisa
  1. Zerodate T26 RGB LED Replacement, Scroll Wheel: passo 1, imagem 1 %32 Zerodate T26 RGB LED Replacement, Scroll Wheel: passo 1, imagem 2 %32
    • Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
    Pergunte ao FixBot
    Comentar
  2. Zerodate T26 RGB LED Replacement: passo 2, imagem 1 %32 Zerodate T26 RGB LED Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the adhesive pads using precision tweezers or the iFixit opening tool.
    • Adhesive pads are located on the bottom of the mouse.
    Pergunte ao FixBot
    Comentar
  3. Zerodate T26 RGB LED Replacement: passo 3, imagem 1 %32 Zerodate T26 RGB LED Replacement: passo 3, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws.
    Pergunte ao FixBot
    Comentar
  4. Zerodate T26 RGB LED Replacement: passo 4, imagem 1 %32 Zerodate T26 RGB LED Replacement: passo 4, imagem 2 %32
    • Carefully pull the middle shell apart from the bottom plate.
    • The circuit board should then be visible and attached to the bottom plate.
    Pergunte ao FixBot
    Comentar
  5. Zerodate T26 RGB LED Replacement: passo 5, imagem 1 %32 Zerodate T26 RGB LED Replacement: passo 5, imagem 2 %32
    • Remove the scroll wheel by pushing it to the right and pulling up.
    Pergunte ao FixBot
    Comentar
  6. Zerodate T26 RGB LED Replacement, RGB LED: passo 6, imagem 1 %32 Zerodate T26 RGB LED Replacement, RGB LED: passo 6, imagem 2 %32 Zerodate T26 RGB LED Replacement, RGB LED: passo 6, imagem 3 %32
    • Disconnect the battery from the circuit board.
    • Use the precision tweezers to remove the tape from the circuit board.
    • Carefully pull apart the circuit board from the bottom shell.
    Pergunte ao FixBot
    Comentar
  7. Zerodate T26 RGB LED Replacement: passo 7, imagem 1 %32
    • Desolder the LEDs from the circuit board and solder on the new LEDs following the soldering guide.
    • Please be sure to review safety guidelines and guided steps on soldering/desoldering before attempting remove of LEDs
    Pergunte ao FixBot
    Comentar
Conclusão
Janice Rullan
Membro desde: 03/13/23
662 Reputação
Autoria de 6 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 375
