Ir para o conteúdo principal
ZTE Tempo Headphone Jack Replacement
O que você precisa
  1. ZTE Tempo Headphone Jack Replacement, Headphone Jack: passo 1, imagem 1 %32 ZTE Tempo Headphone Jack Replacement, Headphone Jack: passo 1, imagem 2 %32
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. ZTE Tempo Headphone Jack Replacement: passo 2, imagem 1 %32 ZTE Tempo Headphone Jack Replacement: passo 2, imagem 2 %32 ZTE Tempo Headphone Jack Replacement: passo 2, imagem 3 %32
    • Unplug wires by pushing up with the plastic opening tool
  3. ZTE Tempo Headphone Jack Replacement: passo 3, imagem 1 %32 ZTE Tempo Headphone Jack Replacement: passo 3, imagem 2 %32
    • Push up with the plastic opening tool to remove the motherboard.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the motherboard.
  4. ZTE Tempo Headphone Jack Replacement: passo 4, imagem 1 %32
    • Unplug the wire by pushing up with the plastic opening tool in the back of the motherboard.
  5. ZTE Tempo Headphone Jack Replacement: passo 5, imagem 1 %32 ZTE Tempo Headphone Jack Replacement: passo 5, imagem 2 %32
    • Desolder and remove in front of the motherboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 169
