Ir para o conteúdo principal
ZTE Prestige 2 Back Camera Replacement
O que você precisa
  1. ZTE Prestige 2 Back Camera Replacement, Battery: passo 1, imagem 1 %32 ZTE Prestige 2 Back Camera Replacement, Battery: passo 1, imagem 2 %32 ZTE Prestige 2 Back Camera Replacement, Battery: passo 1, imagem 3 %32
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
    Pergunte ao FixBot
    Comentar
  2. ZTE Prestige 2 Back Camera Replacement: passo 2, imagem 1 %32 ZTE Prestige 2 Back Camera Replacement: passo 2, imagem 2 %32
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  3. ZTE Prestige 2 Back Camera Replacement, Back Panel: passo 3, imagem 1 %32 ZTE Prestige 2 Back Camera Replacement, Back Panel: passo 3, imagem 2 %32 ZTE Prestige 2 Back Camera Replacement, Back Panel: passo 3, imagem 3 %32
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
    Pergunte ao FixBot
    Comentar
  4. ZTE Prestige 2 Back Camera Replacement: passo 4, imagem 1 %32 ZTE Prestige 2 Back Camera Replacement: passo 4, imagem 2 %32 ZTE Prestige 2 Back Camera Replacement: passo 4, imagem 3 %32
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
    Pergunte ao FixBot
    Comentar
  5. ZTE Prestige 2 Back Camera Replacement, Back Camera: passo 5, imagem 1 %32 ZTE Prestige 2 Back Camera Replacement, Back Camera: passo 5, imagem 2 %32 ZTE Prestige 2 Back Camera Replacement, Back Camera: passo 5, imagem 3 %32
    • Use the iFixit opening pick and wedge it under the press fit connector beside the camera located at the top center of the device to pop it off.
    • Remove the camera.
    • The camera cable near the press fit connector is delicate, ripping it will cause permanent damage.
    • The base of the camera may be glued down which may lead to accidental ripping during removal. Use the flat end of a metal spudger to pry it up if necessary.
    Pergunte ao FixBot
    Comentar
Conclusão
Maria Stock
Membro desde: 01/31/20
524 Reputação
Autoria de 5 guias
Equipe
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 Membro de UW Stout, Team S1-G4, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 33
Ao todo: 474
