Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide has step-by-step instructions on how to replace your ZTE Max XL charging port, in order to do this you must first remove the phone's battery. To determine if you need to replace your charging port refer to our Troubleshooting Guide.
  1. Before any disassembly, make sure the phone is powered off. Use the SIM Card Eject Tool to remove the SIM card tray. To do this, insert the key into the hole on the side of the phone near the SIM card tray.
    • Before any disassembly, make sure the phone is powered off.
    • Use the SIM Card Eject Tool to remove the SIM card tray. To do this, insert the key into the hole on the side of the phone near the SIM card tray.
  2. Apply the iOpener to the back of the phone. For instructions on how to use the iOpener, use this guide. On the phone shown there was adhesive on the top and bottom of the phone backing, so we specifically heated these areas.
    • Apply the iOpener to the back of the phone. For instructions on how to use the iOpener, use this guide.
    • On the phone shown there was adhesive on the top and bottom of the phone backing, so we specifically heated these areas.
    • Do not heat the phone too much in one area - it may warp the plastic backing.
  3. Starting at one corner, wedge the plastic opening pick underneath the plastic backing to start undoing the tabs that connect the backing to the phone. There are 3 tabs on top and bottom, and 6 on each side. Use extreme caution to not puncture the lithium ion battery. Use extreme caution to not puncture the lithium ion battery.
    • Starting at one corner, wedge the plastic opening pick underneath the plastic backing to start undoing the tabs that connect the backing to the phone. There are 3 tabs on top and bottom, and 6 on each side.
    • Use extreme caution to not puncture the lithium ion battery.
  4. Carefully undo the ribbon wire for the fingerprint scanner before full removal of the backing. There are two 3.4mm JIS 00 screws that hold the wire in place, one may be under a lock sticker. Remove the screws with the JIS 00 screwdriver.
    • Carefully undo the ribbon wire for the fingerprint scanner before full removal of the backing.
    • There are two 3.4mm JIS 00 screws that hold the wire in place, one may be under a lock sticker. Remove the screws with the JIS 00 screwdriver.
  5. After removal of the two 3.4mm JIS 00 screws, disconnect the connector that attaches the ribbon wire from the main part of the phone. After removal of the two 3.4mm JIS 00 screws, disconnect the connector that attaches the ribbon wire from the main part of the phone.
    • After removal of the two 3.4mm JIS 00 screws, disconnect the connector that attaches the ribbon wire from the main part of the phone.
  6. Telas LCD de reposição iPhone (com ferramentas)
    A opção econômica, coberta por nossa garantia vitalícia.
    Confira os kits
    Reduza os custos de reparo, não a qualidade.
    Confira os kits
  7. Remove the nineteen 3.4mm JIS 00 screws on the perimeter of the back using the JIS 00 screwdriver. Remove the nineteen 3.4mm JIS 00 screws on the perimeter of the back using the JIS 00 screwdriver. Remove the nineteen 3.4mm JIS 00 screws on the perimeter of the back using the JIS 00 screwdriver.
    • Remove the nineteen 3.4mm JIS 00 screws on the perimeter of the back using the JIS 00 screwdriver.
  8. Use a plastic opening pick between the screen and side trim battery cover to remove the screen. If the SIM Card is still in place during removal of the siding, take care during removal to avoid damaging the SIM Card. If the SIM Card is still in place during removal of the siding, take care during removal to avoid damaging the SIM Card.
    • Use a plastic opening pick between the screen and side trim battery cover to remove the screen.
    • If the SIM Card is still in place during removal of the siding, take care during removal to avoid damaging the SIM Card.
  9. On the top left of the battery, flip the metal clips with a pick and remove the battery ribbon from the shell.
    • On the top left of the battery, flip the metal clips with a pick and remove the battery ribbon from the shell.
  10. Using the iOpener heating pack, CAREFULLY apply heat to the battery. For instructions of how to use the iOpener, use this guide
    • Using the iOpener heating pack, CAREFULLY apply heat to the battery. For instructions of how to use the iOpener, use this guide
    • Use extreme caution to not overheat the battery. Never use any open flames or high heat.
    • Adhesive is used to secure the battery to the phone. If you're having problems you may need to heat the screen as well.
  11. Using the iFixit opening tools carefully pry the edges of the battery away from the casing. While prying, take care to not scrape the wires underneath the battery. While prying, take care to not scrape the wires underneath the battery.
    • Using the iFixit opening tools carefully pry the edges of the battery away from the casing.
    • While prying, take care to not scrape the wires underneath the battery.
  12. With the battery removed, you can now insert the new battery or replace other parts within your phone.
    • With the battery removed, you can now insert the new battery or replace other parts within your phone.
  13. After you take out the battery, remove the 8 black wires using the spudger. Flip the metal connectors to release the wires. One of the tabs will remove the back-facing camera. One of the tabs will remove the back-facing camera.
    • After you take out the battery, remove the 8 black wires using the spudger. Flip the metal connectors to release the wires.
    • One of the tabs will remove the back-facing camera.
  14. After disconnection of all the metal tabs, insert the spudger underneath the bottom of the phone's circuit board. Gently pry upwards, taking care to not scrape any of the electronics beneath the board.
    • After disconnection of all the metal tabs, insert the spudger underneath the bottom of the phone's circuit board.
    • Gently pry upwards, taking care to not scrape any of the electronics beneath the board.
  15. With the bottom circuit board removed, the charging port will be attached to it.
    • With the bottom circuit board removed, the charging port will be attached to it.
    • To replace your charging port, insert your replacement charging port
Conclusão
7 outras pessoas concluíram este guia.
Olivia Wolf
Membro desde: 15-02-2018
1.352 Reputação
5 Guias de autoria
equipe
UW Stout, Team S8-G2, Ogden Spring 2018 Membro de UW Stout, Team S8-G2, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G2
4 Membros
5 Guias de autoria
Too much hassle just for the charging port. You can basically just disconnect it’s connection and pop up a new one lol
Rafael B - Responder
I was thinking the same thing but I appreciate that they documented every step as it in the manual I’m sure
Rick Diaz - Responder
For someone who is looking to make this as simple as possible it is important to note that although it is super important to disconnect the battery first, you do not need to remove the battery ruining the adhesive. All you need to do after unplugging the battery is disconnect the flex cable and the black jumper wire and pull out the board, this is of course after you have the phone fully opened up. I’m not saying they did it wrong because I know they did it right and very thorough, if you are new to this and working on your own phone in a hurry, do what I said. Good luck in your repairs!
Caleb Beilby - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 15
Últimos 30 dias: 61
Duração total: 3,893
