Introdução
When the display on your ZTE Axon 7 smartphone is cracked or is displaying lines and/or won't display anything at all, the screen assembly may need to be replaced. To view some troubleshooting issues for the display, visit the troubleshooting page.
The entire assembly must be replaced instead of just the glass or the LCD. Both are connected as one. This process is tedious, yet straightforward and requires some patience. In this guide, all internal parts must be removed from the screen assembly and placed into a new screen assembly.
Before beginning this repair, power off your phone and unplug it from the charger.
O que você precisa
Using the SIM Tray Removal Tool, press the pin into the hole on the SIM Tray (located on the top left of the device) to eject the tray.
Use a Phillips #00 screwdriver to remove three 2.0 mm screw securing brackets on the top and bottom of the battery.
Use the angled tweezers and lift the bottom bracket up and off the phone.
Use the angled tweezers to slide the top bracket up and off the phone.
Use a Phillips #00 screwdriver to remove a single 2.0 mm screw near the vibration motor.
Repeat the steps in reverse order to reassemble into new display assembly. Use the 2mm Tesa Tape to secure the battery and speaker grills into place during reassembly.
Uma outra pessoa concluiu este guia.
