Ir para o conteúdo principal
Yuneec ST16S Carrying Handle Replacement
O que você precisa
    1. Yuneec ST16S Carrying Handle Replacement, Battery: passo 1, imagem 1 %32
      • Hold down the button located above the battery while applying downward pressure to the battery.
      Pergunte ao FixBot
      Comentar
    2. Yuneec ST16S Carrying Handle Replacement: passo 2, imagem 1 %32 Yuneec ST16S Carrying Handle Replacement: passo 2, imagem 2 %32
      • While still holding down the button, slide the battery out of its slot.
      Pergunte ao FixBot
      Comentar
    1. Yuneec ST16S Carrying Handle Replacement, Backplate: passo 3, imagem 1 %32
      • Remove the single screw from the battery compartment.
      Pergunte ao FixBot
      Comentar
    2. Yuneec ST16S Carrying Handle Replacement: passo 4, imagem 1 %32 Yuneec ST16S Carrying Handle Replacement: passo 4, imagem 2 %32
      • Remove the rubber bumpers from the back of the device using a spudger.
      Pergunte ao FixBot
      Comentar
    3. Yuneec ST16S Carrying Handle Replacement: passo 5, imagem 1 %32 Yuneec ST16S Carrying Handle Replacement: passo 5, imagem 2 %32
      • Remove the two screws located under each of the rubber bumpers.
      Pergunte ao FixBot
      Comentar
    4. Yuneec ST16S Carrying Handle Replacement: passo 6, imagem 1 %32 Yuneec ST16S Carrying Handle Replacement: passo 6, imagem 2 %32 Yuneec ST16S Carrying Handle Replacement: passo 6, imagem 3 %32
      • Remove the three screws along the top of the device.
      Pergunte ao FixBot
      Comentar
    5. Yuneec ST16S Carrying Handle Replacement: passo 7, imagem 1 %32 Yuneec ST16S Carrying Handle Replacement: passo 7, imagem 2 %32
      • Carefully remove the backplate from the device.
      Pergunte ao FixBot
      Comentar
    1. Yuneec ST16S Carrying Handle Replacement, Carrying Handle: passo 8, imagem 1 %32 Yuneec ST16S Carrying Handle Replacement, Carrying Handle: passo 8, imagem 2 %32
      • Remove the screws from the clips on both ends of the handle.
      Pergunte ao FixBot
      Comentar
    2. Yuneec ST16S Carrying Handle Replacement: passo 9, imagem 1 %32 Yuneec ST16S Carrying Handle Replacement: passo 9, imagem 2 %32
      • Slide the clips away from the handle.
      Pergunte ao FixBot
      Comentar
    3. Yuneec ST16S Carrying Handle Replacement: passo 10, imagem 1 %32
      • Remove the handle from the device.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021 Membro de UMass Dartmouth, Team 4-2, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G2
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 21
Ao todo: 205
