Introdução
Use this guide to replace the loudspeaker on your Xiaomi Redmi Note 9S.
You’ll need replacement adhesive to reattach components when reassembling the device.
O que você precisa
Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Use a Phillips screwdriver to remove the eleven 3.8 mm-long screws securing the motherboard cover.
Insert the tip of an opening pick underneath the right edge of the motherboard cover.
Twist the opening pick sideways to pry up the motherboard cover.
Use a spudger to disconnect the battery flex cable by prying the connector straight up from its socket.
Use a Phillips screwdriver to remove the seven 3.8 mm-long screws securing the loudspeaker assembly.
Insert an opening pick into the gap between the right edge of the loudspeaker assembly and the frame.
Twist the opening pick sideways to pry up the loudspeaker assembly.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Uma outra pessoa concluiu este guia.
