Ir para o conteúdo principal
Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement
O que você precisa
  1. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement, Xiaomi Redmi Note 8T Rear Glass Removal: passo 1, imagem 1 %32
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 2, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 2, imagem 2 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 2, imagem 3 %32
    • Secure a suction handle to the bottom of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 3, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 3, imagem 2 %32
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    • Don't remove the suction handle yet. You're going to use it later in the removal procedure as a rear glass stand.
  4. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 4, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 4, imagem 2 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 4, imagem 3 %32
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 5, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 5, imagem 2 %32
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 6, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 6, imagem 2 %32
    • Do not insert the opening pick deeper than 5 mm to avoid damaging the fingerprint connector.
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
    • Do not remove the rear glass all the way yet, the fingerprint cable is still connected to the motherboard.
  7. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 7, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 7, imagem 2 %32
    • Carefully fold the rear glass to the right side of the phone. Use the suction handle as a stand for the rear glass.
  8. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 8, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 8, imagem 2 %32
    • Use a spudger to pry up and disconnect the fingerprint flex cable.
    • Remove the rear glass.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  9. Cuidado: as etapas de 9 a 11 são provenientes de um guia marcado como em andamento.
    Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement, Xiaomi Redmi Note 8T Motherboard Cover Removal: passo 9, imagem 1 %32
    • Remove the eleven Phillips #00 screws (3.9 mm length).
  10. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 10, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 10, imagem 2 %32
    • Insert the tip of an opening pick underneath the bottom edge of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  11. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 11, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 11, imagem 2 %32
    • Remove the motherboard cover including the black protective foil that covers the battery.
  12. Cuidado: a etapa 12 é proveniente de um guia marcado como em andamento.
    Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement, Xiaomi Redmi Note 8T Battery Disconnect: passo 12, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement, Xiaomi Redmi Note 8T Battery Disconnect: passo 12, imagem 2 %32
    • Use a spudger to pry up and disconnect the battery flex cable.
  13. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement, IPS LCD Screen & Digitizer: passo 13, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement, IPS LCD Screen & Digitizer: passo 13, imagem 2 %32
    • Use a spudger to pry up and disconnect the display flex cable.
  14. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 14, imagem 1 %32
    • Remove the seven Phillips #00 screws (3.9 mm length).
  15. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 15, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 15, imagem 2 %32
    • Slide an opening pick underneath the top edge of the daughterboard cover.
    • Use the opening pick to pry up the daughterboard cover.
  16. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 16, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 16, imagem 2 %32
    • Remove the daughterboard cover.
  17. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 17, imagem 1 %32
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
  18. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 18, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 18, imagem 2 %32
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the phone.
    • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the screen with the suction handle to create a small gap between the cover and the frame.
    • Insert an iFlex between the midframe and the screen to create a bigger gap. Leave the iFlex in the gap to prevent the screen from resealing.
  19. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 19, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 19, imagem 2 %32
    • Insert an opening pick in the gap you createtd in the step before. You can remove the iFlex afterwards.
    • Start to cut the adhesive by sliding the opening pick to the bottom right corner.
  20. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 20, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 20, imagem 2 %32
    • Insert a second opening pick and slide it to the bottom left corner of the screen to cut the adhesive.
    • Leave the picks in their place to prevent the adhesive from resealing.
  21. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 21, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 21, imagem 2 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 21, imagem 3 %32
    • Insert a third opening pick under the bottom left corner of the phone.
    • Slide the opening pick up to the top left corner to cut the adhesive. Leave it there to prevent the adhesive from resealing.
    • If cutting becomes too difficult, reheat and reapply the iOpener.
  22. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 22, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 22, imagem 2 %32
    • Insert a fourth opening pick at the top left corner.
    • When nearing the front facing camera, only work with the tip of the opening pick to avoid damaging or smearing the camera.
    • Slide the opening pick along the top edge of the phone to cut the adhesive. Leave the pick in the top right corner of the screen to prevent the adhesive from resealing.
  23. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 23, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 23, imagem 2 %32
    • Insert a fifth opening pick and slide it along the right edge of the phone to cut the remaining adhesive.
    • Try not to remove the display all the way yet, the display cable is still threaded through the frame and possible adhered on the inner side of the midframe.
  24. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 24, imagem 1 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 24, imagem 2 %32 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: passo 24, imagem 3 %32
    • Thread the display flex cable through the gap in the midframe and remove the display.
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
14 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
203.632 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 17.163 guias
6 comentários
Hervorande Anleitung !
Alois Springer - Responder
Bonjour, c'est grâce à ce tuto que je suis fier de vous dire avoir réussi à changer mon écran seul sans payer un réparateur.
Pour enlever l ‘écran je n ai pas réussi à soulever l’écran avec une ventouse en chauffant avec un sèche cheveux ( alors que ça a bien fonctionné pour la vitre arrière).
J ai improvisé alors j ai du élargir une fissure avec un petit tournevis pour soulever l’écran du châssis et ainsi insérer le mediator comme prévu
Merci pour ce tuto…
FRA NCK - Responder
After heating to take apart back glass and screen, both buttons power and volume are loose and dont stay on their place. they fall, even if i put them back. any idea why this happens?
ifixthem - Responder
ok i found why. buttons have a black thin plastic “lock" check it under microscope mine had “twisted
ifixthem -
Welchen Kleber sollte man verwenden, um das Display auf den Rahmen/ Chassis zu kleben?
Danke für die gute Anleitung!
koston85 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 42
Últimos 30 dias: 220
Duração total: 13,262
