Ir para o conteúdo principal
Xiaomi Redmi Note 10S Screen Replacement
O que você precisa
  1. Xiaomi Redmi Note 10S Screen Replacement, Heat the back cover: passo 1, imagem 1 %32
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Xiaomi Redmi Note 10S Screen Replacement, Insert an opening pick: passo 2, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Insert an opening pick: passo 2, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Insert an opening pick: passo 2, imagem 3 %32
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  3. Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 3, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 3, imagem 2 %32
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 4, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 4, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 4, imagem 3 %32
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    • You can remove the suction cup now.
  5. Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 5, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 5, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 5, imagem 3 %32
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 6, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 6, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 6, imagem 3 %32
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  7. Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 7, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 7, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 7, imagem 3 %32
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
  8. Xiaomi Redmi Note 10S Screen Replacement, Remove the back cover: passo 8, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Remove the back cover: passo 8, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Remove the back cover: passo 8, imagem 3 %32
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. Xiaomi Redmi Note 10S Screen Replacement, Unfasten the camera cover screws: passo 9, imagem 1 %32
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the camera cover.
    • One of the screws is hidden beneath an orange sticker.
  10. Xiaomi Redmi Note 10S Screen Replacement, Pry up the camera cover: passo 10, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Pry up the camera cover: passo 10, imagem 2 %32
    • Insert an opening pick into the gap beneath the bottom edge of the camera cover.
    • Pry up the camera cover with your opening pick.
  11. Xiaomi Redmi Note 10S Screen Replacement, Remove the camera cover: passo 11, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Remove the camera cover: passo 11, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use your fingers or a pair of tweezers to remove the camera cover.
  12. Xiaomi Redmi Note 10S Screen Replacement, Unfasten the midframe screws: passo 12, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Unfasten the midframe screws: passo 12, imagem 2 %32
    • Use a Phillips screwdriver to remove the twelve 3.9 mm-long screws securing the midframe.
  13. Xiaomi Redmi Note 10S Screen Replacement, Eject the SIM card tray: passo 13, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Eject the SIM card tray: passo 13, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Eject the SIM card tray: passo 13, imagem 3 %32
    • Insert a SIM card eject tool into the small hole in the SIM card tray, located at the left edge of the phone.
    • Press directly into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
  14. Xiaomi Redmi Note 10S Screen Replacement, Disconnect the power and volume button flex cable: passo 14, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Disconnect the power and volume button flex cable: passo 14, imagem 2 %32
    • Use a spudger to disconnect the power and volume button flex cable by prying the connector straight up from its socket.
  15. Xiaomi Redmi Note 10S Screen Replacement, Insert an opening pick: passo 15, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Insert an opening pick: passo 15, imagem 2 %32
    • The midframe of the Xiaomi Redmi Note 10S is held in place by plastic clips.
    • Insert an opening pick between the midframe and display assembly on the left edge of the phone where the SIM tray slot is located.
    • Make sure to insert the opening pick between the midframe and the display frame to avoid separating the screen from the frame.
  16. Xiaomi Redmi Note 10S Screen Replacement, Release the plastic clips: passo 16, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Release the plastic clips: passo 16, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Release the plastic clips: passo 16, imagem 3 %32
    • The plastic clips of the midframe are sitting in place tightly. Releasing them might require some force.
    • Slide the opening pick along the left edge of the phone to release the plastic clips.
  17. Xiaomi Redmi Note 10S Screen Replacement: passo 17, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement: passo 17, imagem 2 %32
    • Slide the opening pick along the bottom edge of the phone to release the plastic clips.
  18. Xiaomi Redmi Note 10S Screen Replacement: passo 18, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement: passo 18, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement: passo 18, imagem 3 %32
    • Slide the opening pick along the right edge of the phone to release the plastic clips.
  19. Xiaomi Redmi Note 10S Screen Replacement: passo 19, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement: passo 19, imagem 2 %32
    • Slide the opening pick along the top edge of the phone to release the remaining plastic clips.
  20. Xiaomi Redmi Note 10S Screen Replacement, Remove the midframe: passo 20, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Remove the midframe: passo 20, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Remove the midframe: passo 20, imagem 3 %32
    • Before removing the midframe make sure the power and volume button flex cable is freed and not tangled with the motherboard to avoid tearing it.
    • Remove the midframe.
  21. Xiaomi Redmi Note 10S Screen Replacement, Disconnect the battery cable: passo 21, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Disconnect the battery cable: passo 21, imagem 2 %32
    • Use a spudger to disconnect the battery flex cable by prying the connector straight up from its socket.
  22. Xiaomi Redmi Note 10S Screen Replacement, Disconnect the daughterboard interconnect cable: passo 22, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Disconnect the daughterboard interconnect cable: passo 22, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Disconnect the daughterboard interconnect cable: passo 22, imagem 3 %32
    • Use a spudger to disconnect both ends of the daughterboard interconnect cable.
    • Remove the daughterboard connection cable.
  23. Xiaomi Redmi Note 10S Screen Replacement, Remove the loudspeaker: passo 23, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Remove the loudspeaker: passo 23, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Remove the loudspeaker: passo 23, imagem 3 %32
    Comprar
    • Use a spudger on the right top edge to lift up the loudspeaker.
    • Use your fingers or a pair of tweezers to remove the loudspeaker.
  24. Xiaomi Redmi Note 10S Screen Replacement, Disconnect the antenna cable: passo 24, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Disconnect the antenna cable: passo 24, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Disconnect the antenna cable: passo 24, imagem 3 %32
    • Use a spudger to disconnect both ends of the antenna cable by prying the connectors straight up from their sockets.
  25. Xiaomi Redmi Note 10S Screen Replacement, Free the antenna cable: passo 25, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Free the antenna cable: passo 25, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Free the antenna cable: passo 25, imagem 3 %32
    • Use a spudger to remove the antenna cable from its recess.
    • Don't release the antenna cable from its clip on the daughterboard. This will make positioning the cable during reassembly easier.
  26. Xiaomi Redmi Note 10S Screen Replacement, Remove the daughterboard: passo 26, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Remove the daughterboard: passo 26, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Remove the daughterboard: passo 26, imagem 3 %32
    • Insert an opening pick into the gap between the front panel and the left edge of the daughterboard.
    • Pry up the daughterboard by twisting the opening pick sideways.
    • Use your fingers or a pair of tweezers to remove the daughterboard.
  27. Xiaomi Redmi Note 10S Screen Replacement, Disconnect the display cable: passo 27, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Disconnect the display cable: passo 27, imagem 2 %32
    • Use a spudger to disconnect the display cable by prying the connector straight up from its socket.
  28. Xiaomi Redmi Note 10S Screen Replacement, Free the display cable: passo 28, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Free the display cable: passo 28, imagem 2 %32
    • Insert a spudger into the opening on the bottom left of the display interconnect cable.
    • Use the spudger to pry up the display interconnect cable to free the display cable.
  29. Xiaomi Redmi Note 10S Screen Replacement, Loosen the display adhesive: passo 29, imagem 1 %32
    • Apply a heated iOpener to the screen for two minutes to loosen the adhesive underneath.
  30. Xiaomi Redmi Note 10S Screen Replacement, Insert an opening pick: passo 30, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Insert an opening pick: passo 30, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Insert an opening pick: passo 30, imagem 3 %32
    • Apply a suction handle to the bottom of the screen.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull the suction cup up with strong, steady force to create a gap.
    • Insert an opening pick into the gap.
  31. Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 31, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 31, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Slice the adhesive: passo 31, imagem 3 %32
    • Slide the opening pick to the bottom right corner of the screen to slice the adhesive.
  32. Xiaomi Redmi Note 10S Screen Replacement: passo 32, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement: passo 32, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement: passo 32, imagem 3 %32
    • When you slice near the display cable, insert only the tip of the opening pick (about 2–3 mm) to avoid damaging the cable.
    • Insert a second opening pick at the bottom right corner and slide it to the bottom left corner of the screen to slice the adhesive.
  33. Xiaomi Redmi Note 10S Screen Replacement: passo 33, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement: passo 33, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement: passo 33, imagem 3 %32
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1–2 minutes to reheat it.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • Leave it in the top left corner to prevent the adhesive from resealing.
  34. Xiaomi Redmi Note 10S Screen Replacement: passo 34, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement: passo 34, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement: passo 34, imagem 3 %32
    • When you slice near the front facing camera, insert only the tip of the opening pick (about 2–3 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
  35. Xiaomi Redmi Note 10S Screen Replacement: passo 35, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement: passo 35, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement: passo 35, imagem 3 %32
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Don't try to remove the display all the way yet, the display cable is still threaded through the front panel assembly.
  36. Xiaomi Redmi Note 10S Screen Replacement, Remove the screen: passo 36, imagem 1 %32 Xiaomi Redmi Note 10S Screen Replacement, Remove the screen: passo 36, imagem 2 %32 Xiaomi Redmi Note 10S Screen Replacement, Remove the screen: passo 36, imagem 3 %32
    • Thread the display flex cable through the gap in the front panel assembly.
    • If your screen is still sticking to the frame, slide the pick around the edges of the phone until the screen completely separates.
    • Remove the screen.
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
8 outras pessoas executaram este guia.
Manuel Haeussermann
Membro desde: 07/13/22
16.286 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.086 guias
4 comentários
This may seem a silly question to all you expert phone repairers out there, but what is a "replacement adhesive to reattach components when reassembling the device." Am I going for a cyano-acrylate, an isopropyl butyl or what?
Anthony Turtle - Responder
Hey Anthony, that's certainly not a silly question! We generally recommend using a Pre-Cut Double-Sided Adhesive Sheet for re-assembling smartphones. You can find a general guide on applying the tape here. If adhesive tape doesn't work in your case, E6000 or T7000 glue should do the job, but make sure to let it cure properly.
Manuel Haeussermann -
I changed my screen redmi note 10s
Got an LCD replacement screen and it's has a redness to it
Should I be worried or will it spell trouble later on?
Niac_04 - Responder
Hi Niac_04, hard to say for sure, but I wouldn't be too worried. It might be a display calibration issue with the replacement screen or a software bug, but it doesn't sound like something that would immediately lead to longterm issues. There are some Reddit threads with reports that sound similar to yours with suggestions like changing the wallpaper or settings, see here and here. Hope this helps!
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 120
Últimos 30 dias: 608
Duração total: 7,559
