Ir para o conteúdo principal
Xbox Series X Fan Replacement
O que você precisa
  1. Xbox Series X Fan Replacement, Uncover the back panel screws: passo 1, imagem 1 %32 Xbox Series X Fan Replacement, Uncover the back panel screws: passo 1, imagem 2 %32
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
    Pergunte ao FixBot
    Comentar
  2. Xbox Series X Fan Replacement: passo 2, imagem 1 %32 Xbox Series X Fan Replacement: passo 2, imagem 2 %32 Xbox Series X Fan Replacement: passo 2, imagem 3 %32
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
    Pergunte ao FixBot
    Comentar
  3. Xbox Series X Fan Replacement, Remove the back panel screws: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $16.96
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
    Pergunte ao FixBot
    Comentar
  4. Xbox Series X Fan Replacement, Unclip the back panel: passo 4, imagem 1 %32 Xbox Series X Fan Replacement, Unclip the back panel: passo 4, imagem 2 %32 Xbox Series X Fan Replacement, Unclip the back panel: passo 4, imagem 3 %32
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
    Pergunte ao FixBot
    Comentar
  5. Xbox Series X Fan Replacement: passo 5, imagem 1 %32 Xbox Series X Fan Replacement: passo 5, imagem 2 %32
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
    Pergunte ao FixBot
    Comentar
  6. Xbox Series X Fan Replacement, Remove the back panel: passo 6, imagem 1 %32 Xbox Series X Fan Replacement, Remove the back panel: passo 6, imagem 2 %32 Xbox Series X Fan Replacement, Remove the back panel: passo 6, imagem 3 %32
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
    Pergunte ao FixBot
    Comentar
  7. Xbox Series X Fan Replacement: passo 7, imagem 1 %32 Xbox Series X Fan Replacement: passo 7, imagem 2 %32 Xbox Series X Fan Replacement: passo 7, imagem 3 %32
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
    Pergunte ao FixBot
    Comentar
  8. Xbox Series X Fan Replacement, Remove the fan screws: passo 8, imagem 1 %32
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
    Pergunte ao FixBot
    Comentar
  9. Xbox Series X Fan Replacement, Disconnect the fan cable: passo 9, imagem 1 %32 Xbox Series X Fan Replacement, Disconnect the fan cable: passo 9, imagem 2 %32 Xbox Series X Fan Replacement, Disconnect the fan cable: passo 9, imagem 3 %32
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
    Pergunte ao FixBot
    Comentar
  10. Xbox Series X Fan Replacement, Remove the fan: passo 10, imagem 1 %32 Xbox Series X Fan Replacement, Remove the fan: passo 10, imagem 2 %32
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
35 outras pessoas executaram este guia.
Carsten Frauenheim
Membro desde: 03/10/20
165.856 Reputação
Autoria de 439 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 26.483 guias
1Comentário do guia
Thank you for the support! I picked up the "Essential Electronics" and it provided all i needed. Excellent tool kit!
Modesto Delvalle Jr - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 39
Últimos 7 dias: 263
Últimos 30 dias: 1,295
Ao todo: 62,741
