Ir para o conteúdo principal
Xbox Series X (Digital Edition) Back Panel Replacement
O que você precisa
  1. Xbox Series X (Digital Edition) Back Panel Replacement, Uncover the back panel screws: passo 1, imagem 1 %32 Xbox Series X (Digital Edition) Back Panel Replacement, Uncover the back panel screws: passo 1, imagem 2 %32
    • Before you begin, completely power down and unplug all cables from your console.
    • Two stickers cover the back panel screws. You can remove the stickers without heating them, though it makes them much easier to remove cleanly.
    • Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
    • Alternatively, you can use a hair dryer to heat the sticker.
    Pergunte ao FixBot
    Comentar
  2. Xbox Series X (Digital Edition) Back Panel Replacement: passo 2, imagem 1 %32 Xbox Series X (Digital Edition) Back Panel Replacement: passo 2, imagem 2 %32 Xbox Series X (Digital Edition) Back Panel Replacement: passo 2, imagem 3 %32
    • Use a pair of angled tweezers to remove the sticker hiding the first screw on the back panel, near the base.
    Pergunte ao FixBot
    Comentar
  3. Xbox Series X (Digital Edition) Back Panel Replacement: passo 3, imagem 1 %32 Xbox Series X (Digital Edition) Back Panel Replacement: passo 3, imagem 2 %32 Xbox Series X (Digital Edition) Back Panel Replacement: passo 3, imagem 3 %32
    • Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
    Pergunte ao FixBot
    Comentar
  4. Xbox Series X (Digital Edition) Back Panel Replacement: passo 4, imagem 1 %32 Xbox Series X (Digital Edition) Back Panel Replacement: passo 4, imagem 2 %32 Xbox Series X (Digital Edition) Back Panel Replacement: passo 4, imagem 3 %32
    • Use the flat end of a spudger to scrape up a corner of the larger sticker until you can grip it with a pair of blunt tweezers.
    • Use blunt tweezers to peel back the sticker to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
    Pergunte ao FixBot
    Comentar
  5. Xbox Series X (Digital Edition) Back Panel Replacement, Remove the back panel screws: passo 5, imagem 1 %32 Xbox Series X (Digital Edition) Back Panel Replacement, Remove the back panel screws: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    Pergunte ao FixBot
    Comentar
  6. Xbox Series X (Digital Edition) Back Panel Replacement, Unclip the back panel: passo 6, imagem 1 %32 Xbox Series X (Digital Edition) Back Panel Replacement, Unclip the back panel: passo 6, imagem 2 %32 Xbox Series X (Digital Edition) Back Panel Replacement, Unclip the back panel: passo 6, imagem 3 %32
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
    Pergunte ao FixBot
    Comentar
  7. Xbox Series X (Digital Edition) Back Panel Replacement: passo 7, imagem 1 %32 Xbox Series X (Digital Edition) Back Panel Replacement: passo 7, imagem 2 %32 Xbox Series X (Digital Edition) Back Panel Replacement: passo 7, imagem 3 %32
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
    Pergunte ao FixBot
    Comentar
  8. Xbox Series X (Digital Edition) Back Panel Replacement, Remove the back panel: passo 8, imagem 1 %32 Xbox Series X (Digital Edition) Back Panel Replacement, Remove the back panel: passo 8, imagem 2 %32 Xbox Series X (Digital Edition) Back Panel Replacement, Remove the back panel: passo 8, imagem 3 %32
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
    Pergunte ao FixBot
    Comentar
  9. Xbox Series X (Digital Edition) Back Panel Replacement: passo 9, imagem 1 %32 Xbox Series X (Digital Edition) Back Panel Replacement: passo 9, imagem 2 %32 Xbox Series X (Digital Edition) Back Panel Replacement: passo 9, imagem 3 %32
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
    Pergunte ao FixBot
    Comentar
Conclusão
Spencer Day
Membro desde: 09/14/22
196.406 Reputação
Autoria de 1.243 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 28.236 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 90
Ao todo: 998
