Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Xbox One Wireless Controller Top Motherboard Replacement
O que você precisa
  1. Xbox One Wireless Controller Top Motherboard Replacement, Battery Pack: passo 1, imagem 1 %32
    • Remove the battery pack cover.
    • Remove batteries.
  2. Xbox One Wireless Controller Top Motherboard Replacement, Side Handles: passo 2, imagem 1 %32 Xbox One Wireless Controller Top Motherboard Replacement, Side Handles: passo 2, imagem 2 %32
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
    Start prying the side plate off underneath the trigger, this makes it easier to disconnect the other clips connecting the side plate to the backplate.
    Brandon - Responder
    One you take it off, is it possible to click it back in?
    Aiden Bear - Responder
    As long as you don’t exceed the couple tons you need to take it off you should be able to put it back.
    Brandon -
    getting those handles back on seems impossible, they just dont fit as well, a gap remains even after snapping into place.
    Dont think ill be doing this in the future
    Spoutin Wyze - Responder
    edit: wiggled the bo9ttom middlewith the handles off and somethign finally “clicked” into place for that extra 1/4 mm for the down arrow on my D-Pad to click back up into place!.
  3. Xbox One Wireless Controller Top Motherboard Replacement, Screws: passo 3, imagem 1 %32 Xbox One Wireless Controller Top Motherboard Replacement, Screws: passo 3, imagem 2 %32
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
    i damaged my screws. how do i get the screws out?
    tenzin - Responder
    wait. i just watched a video guide on ifixit's youtube channel about damaged screws. i'll try those methods.
    tenzin - Responder
    It's a t8 or t9 security bit btw, I got the top two out with a regular T8, but the bottom two and middle needed a T9 Security bit.
    David Loper - Responder
    All five faceplate/backplate screws in the controller I disassembled were T8 security fasteners.
    John Dziedzic - Responder
    Am I doing something wrong because I got the tool it said I needed and got the middle screw out but the others have a bump or something in the center of the screw and it won't fit.
    kolton77 - Responder
    The T8 is only good for the middle screw on my One S controller. The others require something bigger
    Matej Skelo - Responder
    These requires SECURITY Torx bits (they have a cannulated hole in the driver). I don't believe the iFixIt branded driver is cannulated but you can buy a set of bits from DeWalt DWAX200 which is overkill but has what you need.
    jhighsmith - Responder
    The driver that iFixIt sells is cannulated.
    jhighsmith -
    where do you get this dumb ass screw driver
    Jake Zweier - Responder
    iFixit Store #IF145-027-3
    VauWeh - Responder
    You can bypass it with a 1.5mm flathead.
    Marianne Sandling - Responder
    thank you for this. worked for me
    Mr Anderson (Evolluisionist) -
    These screws required a T10, not T8.
    Armand - Responder
    TR9. A $10 kit from Walmart has the bit/driver in it and extra goodies to make life simple.
    Matt Martin - Responder
    As weird as it sounds, the top 2 came out for me with a flathead- but the bottom two and the middle one wont
    macybrooksevans - Responder
    If you damage the middle part of the screws you can still take it out with the same screwdriver.
    Kev God - Responder
    needed a T8H, not easy to see.
    on a grey green xbox one controller
    Michael - Responder
    On my 1708 controller there are two internal screws near the rumble motors that need to be removed with a T6 non security bit to remove the back cover.
    teeedubb - Responder
  4. Xbox One Wireless Controller Top Motherboard Replacement, Backplate: passo 4, imagem 1 %32
    • Remove the backplate.
  5. Xbox One Wireless Controller Top Motherboard Replacement, Faceplate: passo 5, imagem 1 %32
    • Remove the faceplate.
  6. Xbox One Wireless Controller Top Motherboard Replacement, Top Motherboard: passo 6, imagem 1 %32 Xbox One Wireless Controller Top Motherboard Replacement, Top Motherboard: passo 6, imagem 2 %32
    • You may let the rumble motors hang freely out of their sockets.
    • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • De-solder the black and gray wires that are attached to the top motherboard.
    • Remove the rumble motors and set them aside.
    • Be careful while using the soldering iron not to damage other components or hurt yourself.
    • For information on how to solder, click here.
    Steps 6-8 aren't completely necessary, and are very risky if you aren't good at soldering. It would seem the only reason to remove the motherboard and mess with all this soldering is just so you can reach both screws on the trigger in step 10. However, you can reach them already with a small-bodied screwdriver. Although you might have to rest the screwdriver on the black square processor to reach the bottom screw, it shouldn't damage the processor or motherboard to jimmy that screw out.
    Robert Rapier - Responder
    like mentioned by ‘Robert Rapier’ you can skip the de-soldering in most cases,
    for example cleaning or changing the buttons is doable, but the grey and black wires are pretty short
    and wired through the inner case so it can get a bit fiddly and you have to be careful not to damage them in the process.
    If you have a soldering station around i would still recommend using it.
    yKekS Yzz - Responder
    Thanks to above commenters. Can confirm I was able to do a button repair without soldering. Thank you all!
    Matt Hunt - Responder
    If you peal back the Kapton tape mounting the grey/black wires there is enough play to maneuver all the boards for cleaning most of the buttons from a soda spill. Cleaning the dimple buttons on the mother board by immersion requires the de-solder...
    agzero - Responder
  7. Xbox One Wireless Controller Top Motherboard Replacement: passo 7, imagem 1 %32
    • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
    Are these just T6 screws or Torx security T6 that is cannulated?
    Kenan Vickstrom - Responder
    The outer screws are security screws. The ones on the system boards are Torx.
    Rongwey -
  8. Xbox One Wireless Controller Top Motherboard Replacement: passo 8, imagem 1 %32
    • Firmly grip sides of motherboard near the middle.
    • Lift upwards while slightly wiggling the motherboard forward and backward.
    • Lifting the motherboard will require some force.
    Hola, como se instala el software a la nueva placa base ?
    MANSONN755 - Responder
Conclusão
28 outras pessoas executaram este guia.
Liam Gow
Membro desde: 01/22/15
5.285 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 20-15, Maness Winter 2015 Membro de Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
Membros da 5
Autoria de 50 guias
6 comentários
where can i get a top motherborde replacement??
Lol John - Responder
Hi John,
Unfortunately, beyond the parts list given on the main page, I don't know of any other reliable links. I'd suggest Googling the part, or maybe searching on eBay.
Liam Gow -
I was only able to unscrew 2 of the Torx screws. They have a pin right in the middle that doesn't allow for the screwdriver to be fully inserted, or at all. The two screws I was able to unscrew must've had a shorter pin than the others.
Rami Girgis - Responder
These points on the head is what we call a security torx screw. You will need the specific T8 or T6 Security Torx Screwdriver to remove these screws.
jbagge0023 -
You can use a small flat blade screwdriver ;-)
If any of the screws are tight, the centre pin may snap, then you can just use a normal Torx bit.
Lee Houston -
Salut, merci pour le tuto bien expliqué. Je sais déjà démonter, remonter entièrement ma manette, sais-tu ou acheter des carte-mere pour manette xhox one ? Celle qui tient les deux joysticks. Bonne journée
PoolpoHz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 50
Últimos 30 dias: 251
Duração total: 75,922
