Ir para o conteúdo principal
Xbox One Wireless Controller Bottom Motherboard Replacement
O que você precisa
  1. Xbox One Wireless Controller Bottom Motherboard Replacement, Battery Pack: passo 1, imagem 1 %32
    • Remove the battery pack cover.
    • Remove batteries.
    Pergunte ao FixBot
    Comentar
  2. Xbox One Wireless Controller Bottom Motherboard Replacement, Side Handles: passo 2, imagem 1 %32 Xbox One Wireless Controller Bottom Motherboard Replacement, Side Handles: passo 2, imagem 2 %32
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
    Pergunte ao FixBot
    Comentar
  3. Xbox One Wireless Controller Bottom Motherboard Replacement, Screws: passo 3, imagem 1 %32 Xbox One Wireless Controller Bottom Motherboard Replacement, Screws: passo 3, imagem 2 %32
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Xbox One Wireless Controller Bottom Motherboard Replacement, Backplate: passo 4, imagem 1 %32
    • Remove the backplate.
    Pergunte ao FixBot
    Comentar
  5. Xbox One Wireless Controller Bottom Motherboard Replacement, Faceplate: passo 5, imagem 1 %32
    • Remove the faceplate.
    Pergunte ao FixBot
    Comentar
  6. Xbox One Wireless Controller Bottom Motherboard Replacement, Top Motherboard: passo 6, imagem 1 %32 Xbox One Wireless Controller Bottom Motherboard Replacement, Top Motherboard: passo 6, imagem 2 %32
    • You may let the rumble motors hang freely out of their sockets.
    • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • De-solder the black and gray wires that are attached to the top motherboard.
    • Remove the rumble motors and set them aside.
    • Be careful while using the soldering iron not to damage other components or hurt yourself.
    • For information on how to solder, click here.
    Pergunte ao FixBot
    Comentar
  7. Xbox One Wireless Controller Bottom Motherboard Replacement: passo 7, imagem 1 %32
    • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
    Pergunte ao FixBot
    Comentar
  8. Xbox One Wireless Controller Bottom Motherboard Replacement: passo 8, imagem 1 %32
    • Firmly grip sides of motherboard near the middle.
    • Lift upwards while slightly wiggling the motherboard forward and backward.
    • Lifting the motherboard will require some force.
    Pergunte ao FixBot
    Comentar
  9. Xbox One Wireless Controller Bottom Motherboard Replacement, Trigger Rumble Motors: passo 9, imagem 1 %32
    • Remove the yellow tape holding the wires in place on the front of the controller.
    Pergunte ao FixBot
    Comentar
  10. Xbox One Wireless Controller Bottom Motherboard Replacement: passo 10, imagem 1 %32 Xbox One Wireless Controller Bottom Motherboard Replacement: passo 10, imagem 2 %32 Xbox One Wireless Controller Bottom Motherboard Replacement: passo 10, imagem 3 %32
    • Unscrew the two 7mm T6 Hex screws located on underside the triggers.
    Pergunte ao FixBot
    Comentar
  11. Xbox One Wireless Controller Bottom Motherboard Replacement: passo 11, imagem 1 %32
    • Remove the trigger covers.
    Pergunte ao FixBot
    Comentar
  12. Xbox One Wireless Controller Bottom Motherboard Replacement: passo 12, imagem 1 %32
    • Desolder the wires from the motherboard.
    • Remove the rumble motors from its socket and pull the wire with it.
    Pergunte ao FixBot
    Comentar
  13. Xbox One Wireless Controller Bottom Motherboard Replacement, Bottom Motherboard: passo 13, imagem 1 %32 Xbox One Wireless Controller Bottom Motherboard Replacement, Bottom Motherboard: passo 13, imagem 2 %32
    • Remove the six T6 Torx screws located on the bottom motherboard.
    Pergunte ao FixBot
    Comentar
  14. Xbox One Wireless Controller Bottom Motherboard Replacement: passo 14, imagem 1 %32 Xbox One Wireless Controller Bottom Motherboard Replacement: passo 14, imagem 2 %32
    • Remove the bumpers by prying them off of the pegs that secure them, using a spudger. They are located on the front and back of the controller.
    • A standard nylon spudger is recommended for this step. Using a metal spudger near the motherboard as shown risks damaging your device.
    Pergunte ao FixBot
    Comentar
  15. Xbox One Wireless Controller Bottom Motherboard Replacement: passo 15, imagem 1 %32 Xbox One Wireless Controller Bottom Motherboard Replacement: passo 15, imagem 2 %32
    • Lift the piece surrounding the Home button off of its pegs.
    • Pry it off of the other side, using a spudger on the pins.
    • Removing this piece may require a lot of force.
    Pergunte ao FixBot
    Comentar
  16. Xbox One Wireless Controller Bottom Motherboard Replacement: passo 16, imagem 1 %32
    • Remove the bottom motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
31 outras pessoas executaram este guia.
Liam Gow
Membro desde: 01/22/15
5.594 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 20-15, Maness Winter 2015 Membro de Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Membros
Autoria de 54 guias
11Comentários do guia
Is de-soldering optional?
John Gonzalez - Responder Compartilhar
Considering the placement of wires attached by solder on both sides of the top board, it would be quite difficult to reach anything beneath it otherwise. I suppose it depends on what you're trying to achieve.
In any case, you might as well try to move it without desoldering if desoldering is going to be an issue. Make sure not to pull hard, though.
Liam Gow - Responder Compartilhar
I have a question... Will the motherboard you can get at the store here work it the newer controllers with built in headphone jack?
ETHREAL1 - Responder Compartilhar
I would expect not, I'm afraid. The motherboards will probably have different circuitry, even if the shapes are the same, which they may not be.
The position/mounting of the LB and RB buttons on the motherboard piece between the day-one/sans-jack and the newer 3.5mm jack (non-Slim) boards are completely different.
The older revision motherboard has the mountings inverted (pointing downwards to the south end-headset attachment port- of the controller) compared to the newer ones.
The newer ones have the circuit with the bumper buttons mounted pointing to the north end toward the bumpers on the top of the controller.
icho - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 53
Últimos 30 dias: 302
Ao todo: 67,874
