Introdução
If your Xbox One controller has LT/RT issues (or needs manual adjustment), the issue may be due to the magnets. Use this guide to take the controller apart and re-secure the magnets.
Guide warnings
- TO AVOID MELTING THE PLASTIC FRAME WHEN INSTALLING HEATSHRINK TUBING, ADJUST THE LIGHTER/TORCH TO THE LOWEST RELIABLE IGNITION POINT.
- If you use a butane torch, test the setting you are going to use on something you do not mind damaging BEFORE working on the controller. Use ABS to practice.
- Holding the flame once the heatshrink seals may damage the controller frame.
- This is a final solution. Be prepared to write the controller off if this does not fix the problem or makes it worse.
- This fix is specific to Model 1537/1697 controllers.
- This procedure WILL VOID ANY PRESENT WARRANTY. Make sure the warranty is expired if you care about preserving it!
- My controller is 17 months old. It is long out of warranty.
Guide notes
- This guide does not apply to Model 1708 controllers. The procedure to fix the problem is different as heat shrink tubing is not required. However, it can be used as a starting point.
- If you misalign the magnets, you may need a controller frame. Use caution when applying glue. Use of an alignment mark is HIGHLY RECOMMENDED.
O que você precisa
Remove the batteries from your controller (if installed).
Remove the screw under the battery cover label. To do this, puncture the label where it is marked and use a TR8 driver or bit to remove the screw. TIP: This acrew us generally going to be found in the center of the label - feel around with your nail if need be to find it.
Remove the side trim from the controller, along with the 4 TR8 screws. Set the trim and screws aside somewhere safe.
Ferramenta utilizada neste passo:iFixit Opening Tool$4.99
With the screws removed from the back, flip the controller to the front. Remove the front plastic cover.
With the front plastic cover removed, remove the back shell. A plastic pry tool can be used if it is easier.
Remove the shell once the battery tabs are released.
Remove the power button cover from the controller. If the LB/RB assembly is separate, remove this next. A plastic pry tool can also be used.
Remove the wireless sync button. Place this on a bright surface to avoid misplacement.
Ferramenta utilizada neste passo:Precision Utility Knife$4.99
Before cutting the heatshrink, make TWO alignment marks (non-crossing).
After making alignment marks, cut the heatshrink off using a utility knife.
Using the old heatshrink as a reference, cut two new pieces.
After cutting the heatshrink tubing, do a test alignment before applying glue.
These controllers use double sided tape from the factory. Note the dimple side and clean the magnet and frame. Goo Gone can be used on difficult residue.
Once the parts are reasonably clean, do a test alignment and apply tape for final installation.
After verifying the alignment is correct, apply glue to the controller. It is best to let it cure for 24 hours if possible.
Ferramenta utilizada neste passo:Heat Shrink Tubing Assortment$7.99
Once the glue cures, add new heatshrink tubing.
9 outras pessoas executaram este guia.
5Comentários do guia
Do you know any specs on the magnet itself? I have a controller that is missing a magnet, and can’t find any information on the strength of the magnet. Without that there’s no way to get a replacement.
same here cant find it any were
found some on eBay
check on aliexpress they have then in stock
Ma gachette RT reste enfoncé c quoi le problème.
Merci d'avance
