Ir para o conteúdo principal
Xbox Duke Controller Potentiometer Replacement
O que você precisa
  1. Xbox Duke Controller Potentiometer Replacement, Face Plate: passo 1, imagem 1 %32 Xbox Duke Controller Potentiometer Replacement, Face Plate: passo 1, imagem 2 %32 Xbox Duke Controller Potentiometer Replacement, Face Plate: passo 1, imagem 3 %32
    • Remove the seven black 8 mm screws holding the two halves of the Duke together using a Phillips #1 screwdriver.
    • To reach the deeply set screws, use a longer screw driver or a 4.0 socket bit in addition to the PH1 bit.
    Pergunte ao FixBot
    Comentar
  2. Xbox Duke Controller Potentiometer Replacement: passo 2, imagem 1 %32 Xbox Duke Controller Potentiometer Replacement: passo 2, imagem 2 %32 Xbox Duke Controller Potentiometer Replacement: passo 2, imagem 3 %32
    • Remove the two halves of the Duke, placing the top plate face-down so the buttons don't fall out.
    Pergunte ao FixBot
    Comentar
  3. Xbox Duke Controller Potentiometer Replacement, Potentiometer: passo 3, imagem 1 %32 Xbox Duke Controller Potentiometer Replacement, Potentiometer: passo 3, imagem 2 %32
    • Remove the stick caps from the potentiometers.
    Pergunte ao FixBot
    Comentar
  4. Xbox Duke Controller Potentiometer Replacement: passo 4, imagem 1 %32 Xbox Duke Controller Potentiometer Replacement: passo 4, imagem 2 %32
    • Disconnect the connectors attaching the rumble motors to the motherboard using a pair of tweezers.
    • Be gentle when slipping the tweezers underneath the flaps of the connectors; they are fragile and can snap.
    Pergunte ao FixBot
    Comentar
  5. Xbox Duke Controller Potentiometer Replacement: passo 5, imagem 1 %32 Xbox Duke Controller Potentiometer Replacement: passo 5, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the four yellow 8 mm screws holding the motherboard to the bottom half of the controller.
    Pergunte ao FixBot
    Comentar
  6. Xbox Duke Controller Potentiometer Replacement: passo 6, imagem 1 %32 Xbox Duke Controller Potentiometer Replacement: passo 6, imagem 2 %32
    • Remove the motherboard from the bottom half of the controller.
    Pergunte ao FixBot
    Comentar
  7. Xbox Duke Controller Potentiometer Replacement: passo 7, imagem 1 %32 Xbox Duke Controller Potentiometer Replacement: passo 7, imagem 2 %32 Xbox Duke Controller Potentiometer Replacement: passo 7, imagem 3 %32
    • Desolder the connector pins holding the left trigger assembly in place.
    • Remove the trigger assembly by pushing on the black connectors that hold them to the motherboard.
    Pergunte ao FixBot
    Comentar
  8. Xbox Duke Controller Potentiometer Replacement: passo 8, imagem 1 %32
    • Desolder all of the connector pins holding the potentiometer in place.
    • Pull out the potentiometers and solder the new ones into place.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Anthony Casino
Membro desde: 02/15/25
642 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 85
Ao todo: 794
