Ir para o conteúdo principal
Xbox Duke Controller Face Buttons Replacement
O que você precisa
  1. Xbox Duke Controller Face Buttons Replacement, Face Plate: passo 1, imagem 1 %32 Xbox Duke Controller Face Buttons Replacement, Face Plate: passo 1, imagem 2 %32 Xbox Duke Controller Face Buttons Replacement, Face Plate: passo 1, imagem 3 %32
    • Remove the seven black 8 mm screws holding the two halves of the Duke together using a Phillips #1 screwdriver.
    • To reach the deeply set screws, use a longer screw driver or a 4.0 socket bit in addition to the PH1 bit.
    Pergunte ao FixBot
    Comentar
  2. Xbox Duke Controller Face Buttons Replacement: passo 2, imagem 1 %32 Xbox Duke Controller Face Buttons Replacement: passo 2, imagem 2 %32 Xbox Duke Controller Face Buttons Replacement: passo 2, imagem 3 %32
    • Remove the two halves of the Duke, placing the top plate face-down so the buttons don't fall out.
    Pergunte ao FixBot
    Comentar
  3. Xbox Duke Controller Face Buttons Replacement, Face Buttons: passo 3, imagem 1 %32 Xbox Duke Controller Face Buttons Replacement, Face Buttons: passo 3, imagem 2 %32 Xbox Duke Controller Face Buttons Replacement, Face Buttons: passo 3, imagem 3 %32
    • Remove the silicone pads and pull out the directional pad assembly.
    Pergunte ao FixBot
    Comentar
  4. Xbox Duke Controller Face Buttons Replacement: passo 4, imagem 1 %32 Xbox Duke Controller Face Buttons Replacement: passo 4, imagem 2 %32 Xbox Duke Controller Face Buttons Replacement: passo 4, imagem 3 %32
    • Using a plastic opening tool, remove the plastic plate from the bottom of the directional pad assembly.
    • Pull out the silicone pad.
    Pergunte ao FixBot
    Comentar
  5. Xbox Duke Controller Face Buttons Replacement: passo 5, imagem 1 %32 Xbox Duke Controller Face Buttons Replacement: passo 5, imagem 2 %32
    • Remove the silicone pads from the top plate of the controller and remove all of the face buttons.
    • To replace the buttons, line them up with the grooves in the top plate.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Anthony Casino
Membro desde: 02/15/25
642 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 49
Ao todo: 411
