Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Put some feeling back in your gameplay by replacing the vibrator motors in your Xbox 360 wireless controller.
O que você precisa
Depress the battery release button on the top of the controller.
Remove the battery holder from the controller.
Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
Lift the vibration motor out of the front case.
19 outras pessoas executaram este guia.
3 comentários
Hello, I am very concerned about which side of the controller the motor with heavier counterweight should be. Shouldn’t it be on the left side of the controller, since the right side should be used for higher frequency vibrations?
Hi Yado,
Thanks for pointing this out! You are right—the left side have the heavier counterweight. I’ve corrected the relevant step.
Hi there, I believe that the screenshots provided have the vibration motors on the wrong sides. Watching several videos of the disassembly on youtube as well as taking apart my own controller that previously was never opened, the larger heavier motor should be on the right side and the smaller lighter motor should be on the left side.
