Ir para o conteúdo principal
USB Installation Media Creation
O que você precisa
  1. USB Installation Media Creation, Download Rufus: passo 1, imagem 1 %32 USB Installation Media Creation, Download Rufus: passo 1, imagem 2 %32 USB Installation Media Creation, Download Rufus: passo 1, imagem 3 %32
    • THIS PROCEDURE WILL ERASE THE TARGET USB DRIVE! BACKUP THE DRIVE OR USE A NEW ONE IF YOU DO NOT HAVE A DRIVE THAT CAN BE ERASED.
    • If you are reusing an old drive, format it first!
    • To write the ISO, download Rufus. Place this somewhere it is easily found.
  2. USB Installation Media Creation, Download your ISO: passo 2, imagem 1 %32 USB Installation Media Creation, Download your ISO: passo 2, imagem 2 %32 USB Installation Media Creation, Download your ISO: passo 2, imagem 3 %32
    • Authors note: While this guide is being demoed with Linux, it can be used with any bootable ISO - Windows images*, Linux ISOs, utilities like Parted Magic and more.
    • *Windows 11, in it's stock form requires a Microsoft account unless you use the latest version. For writing Windows 11 images, I have made a guide to cover how to work around this. Windows 10 and older do not need this precaution, but versions prior to 3.x will not account for this change.
    • Torrent clients require additional configuration NOT COVERED in this guide. Some distros offer this option and you can use it but every torrent client is a little different.
    • After downloading Rufus, download the ISO you want to write to the USB drive.
  3. USB Installation Media Creation, Locate the ISO: passo 3, imagem 1 %32 USB Installation Media Creation, Locate the ISO: passo 3, imagem 2 %32 USB Installation Media Creation, Locate the ISO: passo 3, imagem 3 %32
    • Default download locations: Windows (Recent versions; 7 and newer): Downloads
    • Plug the USB drive in and select the ISO you want to use.
  4. USB Installation Media Creation, Writing the ISO file: passo 4, imagem 1 %32 USB Installation Media Creation, Writing the ISO file: passo 4, imagem 2 %32 USB Installation Media Creation, Writing the ISO file: passo 4, imagem 3 %32
    • If you are using a system with a buggy Legacy BIOS, consider adding "Add fixes for older BIOSes".
    • Open Rufus and click SELECT. Find the ISO and click Open.
    • Rufus will ask you to choose ISO or DD mode. If unsure, choose ISO mode.
    • After configuring the writing process, click start. Click OK on the formatting warning.
Linha de Chegada
15 outras pessoas executaram este guia.
Nick
Membro desde: 11/10/09
98.710 Reputação
Autoria de 63 guias
2Comentários do guia
Unetbootin does not work anymore and is considered unstable to use when installing any Linux OS, also 4GB USB drives are more than big enough to get the job done
Will - Responder
My reasoning for saying 8GB is because 4GB sticks are all but nonexistent (8GB is more popular now), but if you already own the 4GB stick then it'll work. I even use one from 2006 in the guide, to show that reuse is possible.
Oh really? I always thought it was still a usable option - thanks for letting me know that I was wrong.
Nick -
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 31
Últimos 30 dias: 126
Ao todo: 4,624
