Ir para o conteúdo principal
Wacom Intuos Pro Touch Pad Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Wacom Intuos Pro Touch Pad Replacement, Battery: passo 1, imagem 1 %32 Wacom Intuos Pro Touch Pad Replacement, Battery: passo 1, imagem 2 %32 Wacom Intuos Pro Touch Pad Replacement, Battery: passo 1, imagem 3 %32
    • Orient the device so the bottom casing is facing upwards.
    • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
    Pergunte ao FixBot
    Comentar
  2. Wacom Intuos Pro Touch Pad Replacement: passo 2, imagem 1 %32 Wacom Intuos Pro Touch Pad Replacement: passo 2, imagem 2 %32 Wacom Intuos Pro Touch Pad Replacement: passo 2, imagem 3 %32
    • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
    • The screws are located 40mm in from the edge, so it not necessary to completely remove the rubber if you prefer not to.
    Pergunte ao FixBot
    Comentar
  3. Wacom Intuos Pro Touch Pad Replacement: passo 3, imagem 1 %32 Wacom Intuos Pro Touch Pad Replacement: passo 3, imagem 2 %32
    • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
    • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
    • While going around the edges, make sure you have a tight grip to keep the device from sliding.
    Pergunte ao FixBot
    Comentar
  4. Wacom Intuos Pro Touch Pad Replacement: passo 4, imagem 1 %32 Wacom Intuos Pro Touch Pad Replacement: passo 4, imagem 2 %32
    • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
    Pergunte ao FixBot
    Comentar
  5. Wacom Intuos Pro Touch Pad Replacement: passo 5, imagem 1 %32 Wacom Intuos Pro Touch Pad Replacement: passo 5, imagem 2 %32
    • If not already done, desolder the three colored cables that connect the battery to the motherboard.
    • After desoldering the battery, carefully remove it.
    • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
    • For help soldering, check out our How to Solder and Desolder Connections guide.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 28
Ao todo: 1,054
