Ir para o conteúdo principal
Vtech Kidizoom Smart Watch DX Buttons Replacement
O que você precisa
    1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Master Switch: passo 1, imagem 1 %32
      • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
      • Flip the watch over with the back facing up.
      Pergunte ao FixBot
      Comentar
    2. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 2, imagem 1 %32
      • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 3, imagem 1 %32
      • Gently pull the back plate from the watch casing.
      Pergunte ao FixBot
      Comentar
    4. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 4, imagem 1 %32 Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 4, imagem 2 %32
      • Lift the master switch from the circuit board.
      Pergunte ao FixBot
      Comentar
    1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: passo 5, imagem 1 %32 Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: passo 5, imagem 2 %32
      • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
      • Removal of the circuit board requires soldering.
      • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
      Pergunte ao FixBot
      Comentar
    2. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 6, imagem 1 %32
      • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
      Pergunte ao FixBot
      Comentar
    3. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 7, imagem 1 %32
      • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
      • De-solder the black speaker wire from the circuit board.
      Pergunte ao FixBot
      Comentar
    4. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 8, imagem 1 %32
      • De-solder the red speaker wire, as in the previous step.
      Pergunte ao FixBot
      Comentar
    5. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 9, imagem 1 %32
      • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
      Pergunte ao FixBot
      Comentar
    1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Buttons: passo 10, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Use the the tweezers to pull off the blue rubber cover behind the button.
      • The blue cover is adhesive, so you can stick it back onto the back of the buttons after replacement.
      Pergunte ao FixBot
      Comentar
    2. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 11, imagem 1 %32
      • Use tweezers to separate the backside tab from the front side of the button.
      Pergunte ao FixBot
      Comentar
    3. Vtech Kidizoom Smart Watch DX Buttons Replacement: passo 12, imagem 1 %32
      • Push the other half of the button out of the casing.
      • Repeat steps 11 and 12 for all buttons.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team 10-6, Remmell Spring 2016 Membro de USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
4 Membros
Autoria de 12 guias
1Comentário do guia
Where can you buy the replacement cover?
Katrina Nullatamby - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 52
Ao todo: 6,547
