Ir para o conteúdo principal
Voluas VL001 Speaker Replacement
O que você precisa
  1. Voluas VL001 Speaker Replacement, Storage Tank: passo 1, imagem 1 %32 Voluas VL001 Speaker Replacement, Storage Tank: passo 1, imagem 2 %32 Voluas VL001 Speaker Replacement, Storage Tank: passo 1, imagem 3 %32
    • Remove the lid to the storage tank by using the latch and lifting off.
    • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
  2. Voluas VL001 Speaker Replacement, Battery: passo 2, imagem 1 %32 Voluas VL001 Speaker Replacement, Battery: passo 2, imagem 2 %32 Voluas VL001 Speaker Replacement, Battery: passo 2, imagem 3 %32
    • Place your pet feeder upside down.
    • Squeeze the lock and remove the battery cover.
    • Remove the three 1.5V D alkaline batteries.
  3. Voluas VL001 Speaker Replacement, Housing: passo 3, imagem 1 %32 Voluas VL001 Speaker Replacement, Housing: passo 3, imagem 2 %32 Voluas VL001 Speaker Replacement, Housing: passo 3, imagem 3 %32
    • Insert a metal spudger under the adhesive part of each rubber foot.
    • Pry the foot off.
  4. Voluas VL001 Speaker Replacement: passo 4, imagem 1 %32 Voluas VL001 Speaker Replacement: passo 4, imagem 2 %32
    • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
    • These holes were previously covered by the rubber feet.
    • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
  5. Voluas VL001 Speaker Replacement: passo 5, imagem 1 %32
    • Turn the device over so it is oriented right-side up.
    • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
  6. Voluas VL001 Speaker Replacement, Speaker: passo 6, imagem 1 %32 Voluas VL001 Speaker Replacement, Speaker: passo 6, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the six 11.2 mm screws that hold the motor housing on to the device.
    • Remove the motor assembly and set it to the side.
  7. Voluas VL001 Speaker Replacement: passo 7, imagem 1 %32 Voluas VL001 Speaker Replacement: passo 7, imagem 2 %32
    • Using an opening tool, remove the clear glue covering the two screws.
  8. Voluas VL001 Speaker Replacement: passo 8, imagem 1 %32
    • Use a Phillips #2 screwdriver to remove the two 6 mm screws from the speaker.
  9. Voluas VL001 Speaker Replacement: passo 9, imagem 1 %32 Voluas VL001 Speaker Replacement: passo 9, imagem 2 %32
    • Using your wire strippers/pliers, cut the two wires that are connected to the speaker.
  10. Voluas VL001 Speaker Replacement: passo 10, imagem 1 %32 Voluas VL001 Speaker Replacement: passo 10, imagem 2 %32 Voluas VL001 Speaker Replacement: passo 10, imagem 3 %32
    • Using your wire strippers/pliers, gently crimp the plastic insulation on the wire. Do this several times around the wire to make sure that you can pull it off.
    • Because the wire is so thin, it can be easy to accidentally cut through the wire on this step. Take care to only cut through the insulation.
    • You will want to see a score line in the insulation all around the wire like this.
    • Pull the end of the insulation off, exposing the wire.
  11. Voluas VL001 Speaker Replacement: passo 11, imagem 1 %32 Voluas VL001 Speaker Replacement: passo 11, imagem 2 %32
    • Put the exposed wire on the solder patch, making sure it has good contact with the metal.
    • Solder the wire on to the solder patch.
    • Repeat steps 10 and 11 for the white wire.
Conclusão
Merari Aniga
Membro desde: 01/30/24
459 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 41
