Ir para o conteúdo principal
Visual Land Prestige Pro 7D Reset Button Replacement
O que você precisa
    1. Visual Land Prestige Pro 7D Reset Button Replacement, Back Panel: passo 1, imagem 1 %32
      • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Visual Land Prestige Pro 7D Reset Button Replacement: passo 2, imagem 1 %32
      • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
      • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
      • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
      • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
      Pergunte ao FixBot
      Comentar
    1. Visual Land Prestige Pro 7D Reset Button Replacement, Reset Button: passo 3, imagem 1 %32 Visual Land Prestige Pro 7D Reset Button Replacement, Reset Button: passo 3, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Use the tweezers to lift the grey connector, located next to the reset button, up from the beige housing. It should rotate up, and allow you to slide the ribbon out from under the connector.
      • Although not necessary for replacing the reset button, it is highly recommended to disconnect the ribbon. This ensures it will not get damaged during desoldering.
      Pergunte ao FixBot
      Comentar
    2. Visual Land Prestige Pro 7D Reset Button Replacement: passo 4, imagem 1 %32 Visual Land Prestige Pro 7D Reset Button Replacement: passo 4, imagem 2 %32 Visual Land Prestige Pro 7D Reset Button Replacement: passo 4, imagem 3 %32
      • Soldering guns are hot and can easily damage the device.
      • Desolder the four side dots holding the reset button in place.
      • If this is your first time desoldering, here is a helpful guide to show you Como soldar e dessoldar contatos.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 10-41, Amido Fall 2014 Membro de Cal Poly, Team 10-41, Amido Fall 2014
CPSU-AMIDO-F14S10G41
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 32
Ao todo: 3,930
