Ir para o conteúdo principal
Visual Land Prestige 7G Battery Replacement
O que você precisa
  1. Visual Land Prestige 7G Battery Replacement, Backplate: passo 1, imagem 1 %32 Visual Land Prestige 7G Battery Replacement, Backplate: passo 1, imagem 2 %32
    • Lay your device face-down.
    • Use a Phillips #000 screwdriver to remove the two 4 mm screws next to the AUX port and microphone.
    Pergunte ao FixBot
    Comentar
  2. Visual Land Prestige 7G Battery Replacement: passo 2, imagem 1 %32
    • Pry open the back-plate using a Jimmy.
    • Do this by inserting the tool into the fine thin line between the back-plate and screen at each corner of the device.
    Pergunte ao FixBot
    Comentar
  3. Visual Land Prestige 7G Battery Replacement: passo 3, imagem 1 %32 Visual Land Prestige 7G Battery Replacement: passo 3, imagem 2 %32
    • Lift off the backplate using your hand.
    • If the backplate is stuck, repeat the previous step to ensure all the edges are free.
    Pergunte ao FixBot
    Comentar
  4. Visual Land Prestige 7G Battery Replacement, Battery: passo 4, imagem 1 %32 Visual Land Prestige 7G Battery Replacement, Battery: passo 4, imagem 2 %32 Visual Land Prestige 7G Battery Replacement, Battery: passo 4, imagem 3 %32
    • Use an opening tool to lift the battery from the device.
    • Be careful to not use a metal spudger or tool, as it can bend and harm the battery.
    Pergunte ao FixBot
    Comentar
  5. Visual Land Prestige 7G Battery Replacement: passo 5, imagem 1 %32 Visual Land Prestige 7G Battery Replacement: passo 5, imagem 2 %32
    • Take your soldering gun and carefully remove the red and black wire connecting the battery to the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 23
Ao todo: 286
