Introdução
This guide will help with replacing the speaker located inside of your device. This guide will require soldering.
O que você precisa
Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
Remove the two 7.3 mm panhead screws holding down the speaker with a PH0 driver head.
