Introdução
The device LEDs help light the screen. This guide will assist you in removing them and replacing them.
O que você precisa
Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
Unscrew the two 7.3 mm screws using a PH0 driver head.
Gently lift the beige circuit board and set aside.
Uma outra pessoa concluiu este guia.
