Ir para o conteúdo principal
VTech Little Apps Tablet Battery Internal Wiring Replacement
O que você precisa
  1. VTech Little Apps Tablet Battery Internal Wiring Replacement, Battery: passo 1, imagem 1 %32
    • Remove the 9.9 mm screw covering the batteries with a PH1 driver head.
    Pergunte ao FixBot
    Comentar
  2. VTech Little Apps Tablet Battery Internal Wiring Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to pry the batteries out of their holding.
    • If replacing your batteries with new ones, be careful to insert them as indicated on the device.
    Pergunte ao FixBot
    Comentar
  3. VTech Little Apps Tablet Battery Internal Wiring Replacement, Back Cover: passo 3, imagem 1 %32 VTech Little Apps Tablet Battery Internal Wiring Replacement, Back Cover: passo 3, imagem 2 %32
    • Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
    • Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
    Pergunte ao FixBot
    Comentar
  4. VTech Little Apps Tablet Battery Internal Wiring Replacement: passo 4, imagem 1 %32 VTech Little Apps Tablet Battery Internal Wiring Replacement: passo 4, imagem 2 %32
    • Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
    • Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
    Pergunte ao FixBot
    Comentar
  5. VTech Little Apps Tablet Battery Internal Wiring Replacement, Battery Internal Wiring: passo 5, imagem 1 %32
    • Visually inspect the wires connecting the motherboard to the batteries, looking for damage.
    • Possible damage includes: lead disconnections, wire fraying, and complete wire disconnections.
    Pergunte ao FixBot
    Comentar
  6. VTech Little Apps Tablet Battery Internal Wiring Replacement: passo 6, imagem 1 %32
    • Desolder the internal wire leads connected to the batteries, making sure to remove the positive (red) wire first, and the negative (black) wire second.
    • For assistance with soldering, see this Guide.
    Pergunte ao FixBot
    Comentar
  7. VTech Little Apps Tablet Battery Internal Wiring Replacement: passo 7, imagem 1 %32
    • Next desolder the same black and red internal wire leads connected to the motherboard.
    • The order does not matter for this step.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 2-6, Sullivan Spring 2016 Membro de USF Tampa, Team 2-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G6
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 42
Ao todo: 1,619
