Introdução
Tired of sound not working with headphones plugged into your VTech InnoTab 2. Then follow our quick guide to walk you through replacing a headphone jack on your VTech InnoTab 2.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
O que você precisa
Apply slight pressure and slide the button above the battery cabinet to the right to open.
Remove battery cabinet cover by sliding away from the center of device.
Remove all nine plastic caps from the back of the device using the plastic opening tool.
Remove the two 7 mm screws from the left bumper of the device using a JO screwdriver.
