Ir para o conteúdo principal
VTech CS6719-2 Speaker Replacement
O que você precisa
  1. VTech CS6719-2 Speaker Replacement, Battery: passo 1, imagem 1 %32 VTech CS6719-2 Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Push down on the battery cover in the direction of the arrow located on the back of the phone.
    Pergunte ao FixBot
    Comentar
  2. VTech CS6719-2 Speaker Replacement: passo 2, imagem 1 %32
    • Pull the battery cover off of the back of the phone.
    Pergunte ao FixBot
    Comentar
  3. VTech CS6719-2 Speaker Replacement: passo 3, imagem 1 %32
    • Unplug the battery input cable.
    Pergunte ao FixBot
    Comentar
  4. VTech CS6719-2 Speaker Replacement: passo 4, imagem 1 %32
    • Lift the battery out of the back of the phone.
    Pergunte ao FixBot
    Comentar
  5. VTech CS6719-2 Speaker Replacement, Circuit Board: passo 5, imagem 1 %32 VTech CS6719-2 Speaker Replacement, Circuit Board: passo 5, imagem 2 %32
    • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  6. VTech CS6719-2 Speaker Replacement: passo 6, imagem 1 %32
    • Use the plastic opening tool and spudger to pry the back side of the phone off.
    Pergunte ao FixBot
    Comentar
  7. VTech CS6719-2 Speaker Replacement: passo 7, imagem 1 %32 VTech CS6719-2 Speaker Replacement: passo 7, imagem 2 %32
    • Remove the two 9mm screws located inside the back cover at the top.
    Pergunte ao FixBot
    Comentar
  8. VTech CS6719-2 Speaker Replacement, Speaker: passo 8, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Locate the metal shaped U clip holding the speaker on. Pull up and towards the top of the phone with the flat head tweezers.
    • The clip is loose, it could fall out.
    Pergunte ao FixBot
    Comentar
  9. VTech CS6719-2 Speaker Replacement: passo 9, imagem 1 %32
    • Lift speaker out.
    Pergunte ao FixBot
    Comentar
  10. VTech CS6719-2 Speaker Replacement: passo 10, imagem 1 %32
    • Heat up solder joint on the circuit board where the speaker wires are connected.
    Pergunte ao FixBot
    Comentar
  11. VTech CS6719-2 Speaker Replacement: passo 11, imagem 1 %32
    • Refer to How To Solder and Desolder Connections Como soldar e dessoldar contatos
    • Note: Ensure the old solder joint is removed.
    • Caution: Soldering iron and joint will become very ho
    Pergunte ao FixBot
    Comentar
Conclusão
Benjamin Field
Membro desde: 02/08/16
277 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 1-4, Baechle Spring 2016 Membro de IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Membros
Autoria de 16 guias
2Comentários do guia
Where can I buy the speaker for the phone?
stephenandrewjarvis - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 33
Ao todo: 1,244
