Ir para o conteúdo principal
VTech CS6719-2 Charging Wire Repair
O que você precisa
  1. VTech CS6719-2 Charging Wire Repair, Base: passo 1, imagem 1 %32 VTech CS6719-2 Charging Wire Repair, Base: passo 1, imagem 2 %32
    • Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
    Pergunte ao FixBot
    Comentar
  2. VTech CS6719-2 Charging Wire Repair: passo 2, imagem 1 %32
    • Use the spudger to separate the bottom from the top.
    • There are two clips, located top and bottom, that you have to compress with the spudger.
    Pergunte ao FixBot
    Comentar
  3. VTech CS6719-2 Charging Wire Repair, Charging Wire: passo 3, imagem 1 %32
    • Heat up solder joint on the circuit board where the charging wires are connected. Note: This is the CRD- and CRD+ terminals.
    Pergunte ao FixBot
    Comentar
  4. VTech CS6719-2 Charging Wire Repair: passo 4, imagem 1 %32
    • Refer to How to Solder and Desolder connections Como soldar e dessoldar contatos
    • Note: Ensure the old solder joint is removed.
    • Caution: Soldering iron and joint will become very hot.
    Pergunte ao FixBot
    Comentar
  5. VTech CS6719-2 Charging Wire Repair: passo 5, imagem 1 %32
    • Heat up solder joint on the base unit where the charging wires are connected.
    Pergunte ao FixBot
    Comentar
  6. VTech CS6719-2 Charging Wire Repair: passo 6, imagem 1 %32
    • Take a wire of solder and apply to joint on board to remove the extra solder.
    • Remove charging wire connection.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
IUPUI, Team 1-4, Baechle Spring 2016 Membro de IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 35
Ao todo: 1,686
