Ir para o conteúdo principal
VTech Baby's Learning Laptop LEDs Replacement
O que você precisa
    1. VTech Baby's Learning Laptop LEDs Replacement, LEDs: passo 1, imagem 1 %32
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      Pergunte ao FixBot
      Comentar
    2. VTech Baby's Learning Laptop LEDs Replacement: passo 2, imagem 1 %32
      • Remove the battery door.
      • Take out the batteries.
      Pergunte ao FixBot
      Comentar
    3. VTech Baby's Learning Laptop LEDs Replacement: passo 3, imagem 1 %32 VTech Baby's Learning Laptop LEDs Replacement: passo 3, imagem 2 %32
      • Using a Phillips #0 screwdriver, unscrew the six 7.3mm screws holding the screen together.
      Pergunte ao FixBot
      Comentar
    4. VTech Baby's Learning Laptop LEDs Replacement: passo 4, imagem 1 %32 VTech Baby's Learning Laptop LEDs Replacement: passo 4, imagem 2 %32 VTech Baby's Learning Laptop LEDs Replacement: passo 4, imagem 3 %32
      • With the lid closed, position the device such that the handle is pointing towards you.
      • Using your fingers, gently pry open the cover from the hinge.
      • Attempting to remove the cover while the lid is still open may cause unwanted damage to the device.
      Pergunte ao FixBot
      Comentar
    5. VTech Baby's Learning Laptop LEDs Replacement: passo 5, imagem 1 %32
      • Remove two 6.0mm screws from the LED array using a Phillips #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    6. VTech Baby's Learning Laptop LEDs Replacement: passo 6, imagem 1 %32
      • Pickup the array by the opening in the center of the board.
      • Remove the faulty LEDs by desoldering each from the board. You may refer to this soldering guide if necessary.
      • Movement of the array will be limited as it is still attached to the main device board.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team 12-2, Blackwell Fall 2015 Membro de USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Membros
Autoria de 35 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 36
Ao todo: 1,580
