Ir para o conteúdo principal
Turtle Beach Recon 70P Microphone Replacement
O que você precisa
  1. Turtle Beach Recon 70P Microphone Replacement, Microphone: passo 1, imagem 1 %32 Turtle Beach Recon 70P Microphone Replacement, Microphone: passo 1, imagem 2 %32
    • Before continuing, remove the left ear pad with the earpad replacement guide.
    • Ensure that you are removing the side that houses the microphone.
    • Use a spudger to pry up the black plastic housing.
    • Remove the plastic cover.
    Pergunte ao FixBot
    Comentar
  2. Turtle Beach Recon 70P Microphone Replacement: passo 2, imagem 1 %32 Turtle Beach Recon 70P Microphone Replacement: passo 2, imagem 2 %32 Turtle Beach Recon 70P Microphone Replacement: passo 2, imagem 3 %32
    • Use a Phillips screwdriver remove the two 5 mm screws that secure the motherboard.
    Pergunte ao FixBot
    Comentar
  3. Turtle Beach Recon 70P Microphone Replacement: passo 3, imagem 1 %32 Turtle Beach Recon 70P Microphone Replacement: passo 3, imagem 2 %32 Turtle Beach Recon 70P Microphone Replacement: passo 3, imagem 3 %32
    • Use a Phillips screwdriver to remove the single 8 mm screw under the motherboard that secures the microphone.
    Pergunte ao FixBot
    Comentar
  4. Turtle Beach Recon 70P Microphone Replacement: passo 4, imagem 1 %32 Turtle Beach Recon 70P Microphone Replacement: passo 4, imagem 2 %32 Turtle Beach Recon 70P Microphone Replacement: passo 4, imagem 3 %32
    • You may need to move the wire connecting to the speaker to easily remove the motherboard.
    • Remove the circuit board from the housing.
    • Take care not to strain the wires.
    Pergunte ao FixBot
    Comentar
  5. Turtle Beach Recon 70P Microphone Replacement: passo 5, imagem 1 %32
    • Desolder the microphone connections.
    • Soldering irons can cause burns and fires. Always solder and desolder in a well-ventilated workspace.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 43
Ao todo: 792
