Ir para o conteúdo principal
Turtle Beach PX22 Microphone Replacement
O que você precisa
  1. Turtle Beach PX22 Microphone Replacement, Microphone: passo 1, imagem 1 %32 Turtle Beach PX22 Microphone Replacement, Microphone: passo 1, imagem 2 %32 Turtle Beach PX22 Microphone Replacement, Microphone: passo 1, imagem 3 %32
    • Use your fingers to peel off ear cushion by pinching and pulling off the leather.
    • Use a Philips #00 head screwdriver to remove three 7.1 mm screws around the speaker.
    • The housing will come loose.
    • Gently lift the speaker housing off the ear cup, being careful not to pull on the driver/speaker assembly, which is still connected to a board inside.
    Pergunte ao FixBot
    Comentar
  2. Turtle Beach PX22 Microphone Replacement: passo 2, imagem 1 %32
    • Remove the 7.1 mm screw with a Phillips #2 screwdriver to gain access to the microphone.
    • You may need to pull the wire with the knot out of the way of the screw.
    Pergunte ao FixBot
    Comentar
  3. Turtle Beach PX22 Microphone Replacement: passo 3, imagem 1 %32
    • Use a soldering iron to carefully desolder the microphone wire connectors from the board.
    • Take care not to overheat the board or nearby components.
    • Insert the new microphone and solder the wires into the correct positions.
    • Replace the screw that secures the microphone with a Phillips #2 screwdriver.
    • Pull the excess microphone wire back into the speaker housing.
    • Hold the microphone neck so that it does not rotate when screwing.
    Pergunte ao FixBot
    Comentar
  4. Turtle Beach PX22 Microphone Replacement: passo 4, imagem 1 %32 Turtle Beach PX22 Microphone Replacement: passo 4, imagem 2 %32 Turtle Beach PX22 Microphone Replacement: passo 4, imagem 3 %32
    • Position the speaker on the headset so that the screw holes line up. It should click into place.
    • Use a Phillips #00 screwdriver to secure the three screws.
    • Replace the ear cushion.
    • Use the plastic opening tool to tuck excess leather inside the headset.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Equipe
3Comentários do guia
Where do we buy the mic?
Brit B - Responder Compartilhar
could someone help me say what each and every on of those wire points on this logic board goes to? like 1,2,3,4,5 and 6, what do they go to???
alexalv55 - Responder Compartilhar
i need the cable for my px 24 it broke in my phone how do i get a new cable to fix my px 24 headset
rjbubba1960 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 24
Ao todo: 7,303
