Ir para o conteúdo principal
Trio Stealth-10 Battery Replacement
O que você precisa
  1. Trio Stealth-10 Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
    Pergunte ao FixBot
    Comentar
  2. Trio Stealth-10 Battery Replacement, Battery: passo 2, imagem 1 %32
    • This step will require soldering. If you are unfamiliar with soldering then we recommend that you get help from another person or use the soldering guide made by Ifixit to help.
    • Solder the connections off for the battery.
    Pergunte ao FixBot
    Comentar
  3. Trio Stealth-10 Battery Replacement: passo 3, imagem 1 %32 Trio Stealth-10 Battery Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Disconnect the screen/digitizer connection. Use tweezers and pull each grey end of the connection until there is a small gap between the grey and white on the connector to the motherboard. The connection should be easily removable.
    • Pull the cable away and clear from under the battery to avoid damage to the connection.
    Pergunte ao FixBot
    Comentar
  4. Trio Stealth-10 Battery Replacement: passo 4, imagem 1 %32
    • Pry battery up from adhesive. Use a type of adhesive remover. Nail polish remover works well.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Equipe
UMass Dartmouth, Team 1-4, Miles Fall 2015 Membro de UMass Dartmouth, Team 1-4, Miles Fall 2015
UMASSD-MILES-F15S1G4
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 2,644
