Ir para o conteúdo principal
ThinkPad T420 Hard Drive Replacement
O que você precisa
  1. ThinkPad T420 Hard Drive Replacement, Backup your laptop first!: passo 1, imagem 1 %32 ThinkPad T420 Hard Drive Replacement, Backup your laptop first!: passo 1, imagem 2 %32
    • In most cases, it is better to reinstall the OS from scratch rather than image and restore. If the OS install is old, it is often overdue.
    • Before replacing the drive, backup your personal files. This can be done by hand, or automated.
  2. ThinkPad T420 Hard Drive Replacement, Unplug the system/remove the battery: passo 2, imagem 1 %32 ThinkPad T420 Hard Drive Replacement, Unplug the system/remove the battery: passo 2, imagem 2 %32 ThinkPad T420 Hard Drive Replacement, Unplug the system/remove the battery: passo 2, imagem 3 %32
    • If the system is plugged in, disconnect it from power and remove the battery. Slide the lock tab to the unlocked position.
    • While holding the tab in place, remove the battery.
  3. ThinkPad T420 Hard Drive Replacement, Remove the hard drive door: passo 3, imagem 1 %32 ThinkPad T420 Hard Drive Replacement, Remove the hard drive door: passo 3, imagem 2 %32 ThinkPad T420 Hard Drive Replacement, Remove the hard drive door: passo 3, imagem 3 %32
    • Remove the hard drive door from the system. Use a Phillips #1 bit.
    • Once the screw is loose, remove the drive cover as shown.
  4. ThinkPad T420 Hard Drive Replacement, Remove the hard drive caddy: passo 4, imagem 1 %32 ThinkPad T420 Hard Drive Replacement, Remove the hard drive caddy: passo 4, imagem 2 %32 ThinkPad T420 Hard Drive Replacement, Remove the hard drive caddy: passo 4, imagem 3 %32
    • Pull the black tab on the drive caddy to remove the drive.
  5. ThinkPad T420 Hard Drive Replacement, Remove the drive bumpers: passo 5, imagem 1 %32 ThinkPad T420 Hard Drive Replacement, Remove the drive bumpers: passo 5, imagem 2 %32 ThinkPad T420 Hard Drive Replacement, Remove the drive bumpers: passo 5, imagem 3 %32
    • Remove the hard drive bumpers.
    • Remove the drive screws using a Phillips #1 screwdriver.
  6. ThinkPad T420 Hard Drive Replacement, Remove the old hard drive: passo 6, imagem 1 %32 ThinkPad T420 Hard Drive Replacement, Remove the old hard drive: passo 6, imagem 2 %32
    • Remove the old hard drive from the laptop. If you intend to keep it, store it in a antistatic bag if possible.
  7. ThinkPad T420 Hard Drive Replacement, Install the new hard drive: passo 7, imagem 1 %32 ThinkPad T420 Hard Drive Replacement, Install the new hard drive: passo 7, imagem 2 %32
    • If you are installing an SSD, a 7mm->9.5mm spacer may required.
    • Install your new drive using steps 6 through 3. Reinstall or reimage the operating system.
  8. ThinkPad T420 Hard Drive Replacement, Install the operating system: passo 8, imagem 1 %32
    • If you are installing Windows, use an official ISO or purchase OEM installation media without a product key.
    • In order to save time setting up your system in the future, reinstall Windows from scratch and image the computer once all the drivers and updates are installed.
    • After reassembling the system and confirming the new drive is recognized, reinstall your operating system.
Conclusão
Once you install the new hard drive, reassemble your computer in reverse order. Once you do this, install an OS and restore your data.
6 outras pessoas executaram este guia.
Nick
Membro desde: 11/10/09
88.851 Reputação
Autoria de 49 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.534 guias
3 comentários
Thank you for the meta notes
commander - Responder
Great instructions - you r doing a marvelous job - keep up the fine work !! God bless u !!!!
brixler jandley - Responder
Also - love the cat, I also am a cat fan big time !!!
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 20
Últimos 30 dias: 108
Duração total: 22,741
