Ir para o conteúdo principal
Teddy Ruxpin Motherboard Replacement
O que você precisa
    1. Teddy Ruxpin Motherboard Replacement, Battery: passo 1, imagem 1 %32 Teddy Ruxpin Motherboard Replacement, Battery: passo 1, imagem 2 %32
      • Remove the vest covering the back of the bear.
      • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
      • Captured screws will stay in place, no need to worry about losing this one!
      Pergunte ao FixBot
      Comentar
    2. Teddy Ruxpin Motherboard Replacement: passo 2, imagem 1 %32
      • Pull the tab outward to remove the protective plate for the batteries.
      Pergunte ao FixBot
      Comentar
    3. Teddy Ruxpin Motherboard Replacement: passo 3, imagem 1 %32
      • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
      Pergunte ao FixBot
      Comentar
    1. Teddy Ruxpin Motherboard Replacement, Arms: passo 4, imagem 1 %32 Teddy Ruxpin Motherboard Replacement, Arms: passo 4, imagem 2 %32 Teddy Ruxpin Motherboard Replacement, Arms: passo 4, imagem 3 %32
      • Cut the orange shirt and zip tie.
      • Remove the zip tie.
      Pergunte ao FixBot
      Comentar
    2. Teddy Ruxpin Motherboard Replacement: passo 5, imagem 1 %32
      • Cut across the back seam of the head of the bear along the arrow.
      • This damages the bear's exterior and will require resewing.
      Pergunte ao FixBot
      Comentar
    3. Teddy Ruxpin Motherboard Replacement: passo 6, imagem 1 %32 Teddy Ruxpin Motherboard Replacement: passo 6, imagem 2 %32 Teddy Ruxpin Motherboard Replacement: passo 6, imagem 3 %32
      • Remove the interior of the doll.
      • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
      • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
      Pergunte ao FixBot
      Comentar
    4. Teddy Ruxpin Motherboard Replacement: passo 7, imagem 1 %32 Teddy Ruxpin Motherboard Replacement: passo 7, imagem 2 %32
      • Extract each arm button.
      • Pull on the stuffing of the bear and not the wire to remove the arm button.
      Pergunte ao FixBot
      Comentar
    5. Teddy Ruxpin Motherboard Replacement: passo 8, imagem 1 %32 Teddy Ruxpin Motherboard Replacement: passo 8, imagem 2 %32
      • Pull off the rest of the outside layer of the bear.
      Pergunte ao FixBot
      Comentar
    6. Teddy Ruxpin Motherboard Replacement: passo 9, imagem 1 %32
      • Unplug the arms from the main body.
      Pergunte ao FixBot
      Comentar
    1. Teddy Ruxpin Motherboard Replacement, Housing Cover: passo 10, imagem 1 %32 Teddy Ruxpin Motherboard Replacement, Housing Cover: passo 10, imagem 2 %32 Teddy Ruxpin Motherboard Replacement, Housing Cover: passo 10, imagem 3 %32
      • Unscrew the eleven circled 12.5mm Phillips #1 screws.
      • Remove the top of the housing to access the electronics inside.
      Pergunte ao FixBot
      Comentar
    1. Teddy Ruxpin Motherboard Replacement, Eyes: passo 11, imagem 1 %32
      • Using a Phillips #1 screwdriver, remove the two 12.5mm screws connecting the eyes to the rest of the mechanism.
      Pergunte ao FixBot
      Comentar
    2. Teddy Ruxpin Motherboard Replacement: passo 12, imagem 1 %32 Teddy Ruxpin Motherboard Replacement: passo 12, imagem 2 %32
      • Unplug the two sets of wires connected to the back of the eyes by using moderate to high force.
      Pergunte ao FixBot
      Comentar
    3. Teddy Ruxpin Motherboard Replacement: passo 13, imagem 1 %32
      • Once those wires are disconnected, desolder the wires connected from the eye motherboard.
      Pergunte ao FixBot
      Comentar
    1. Teddy Ruxpin Motherboard Replacement, Mouth: passo 14, imagem 1 %32 Teddy Ruxpin Motherboard Replacement, Mouth: passo 14, imagem 2 %32
      • Remove five 12.5mm Phillips #1 screws.
      • Pull the mouth mechanism out of the shell.
      Pergunte ao FixBot
      Comentar
    2. Teddy Ruxpin Motherboard Replacement: passo 15, imagem 1 %32 Teddy Ruxpin Motherboard Replacement: passo 15, imagem 2 %32
      • Unscrew the last 12.5mm Phillips #1 screw holding the mouth together
      • Open the mouth mechanism
      Pergunte ao FixBot
      Comentar
    1. Teddy Ruxpin Motherboard Replacement, Motherboard: passo 16, imagem 1 %32
      • Remove the two 12.5 MM Phillips #1 screws holding the main motherboard into place.
      Pergunte ao FixBot
      Comentar
    2. Teddy Ruxpin Motherboard Replacement: passo 17, imagem 1 %32
      • Desolder all connections.
      Pergunte ao FixBot
      Comentar
Conclusão
Jayin Patel
Membro desde: 01/23/20
406 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S18-G5, White Winter 2020 Membro de Cal Poly, Team S18-G5, White Winter 2020
CPSU-WHITE-W20S18G5
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 28
Ao todo: 2,223
