Ir para o conteúdo principal
TMY V08 Lens Replacement
O que você precisa
  1. TMY V08 Lens Replacement, Top Panel: passo 1, imagem 1 %32 TMY V08 Lens Replacement, Top Panel: passo 1, imagem 2 %32 TMY V08 Lens Replacement, Top Panel: passo 1, imagem 3 %32
    • Turn the projector upside-down.
    • Remove the six 10.8 mm screws from the bottom of the projector using a Phillips #1 screwdriver.
    • Turn the projector back over and lift the top casing panel off the projector.
    Pergunte ao FixBot
    Comentar
  2. TMY V08 Lens Replacement: passo 2, imagem 1 %32 TMY V08 Lens Replacement: passo 2, imagem 2 %32 TMY V08 Lens Replacement: passo 2, imagem 3 %32
    • Pinch and pull the bundled cable connector from the top panel.
    • Remove the top panel from the projector.
    Pergunte ao FixBot
    Comentar
  3. TMY V08 Lens Replacement, Lens: passo 3, imagem 1 %32 TMY V08 Lens Replacement, Lens: passo 3, imagem 2 %32 TMY V08 Lens Replacement, Lens: passo 3, imagem 3 %32
    • Remove the four 6.4 mm screws from the motherboard using a Phillips #1 screwdriver.
    • Pull back the motherboard to expose the connectors underneath.
    Pergunte ao FixBot
    Comentar
  4. TMY V08 Lens Replacement: passo 4, imagem 1 %32 TMY V08 Lens Replacement: passo 4, imagem 2 %32
    • Rotate the projector counterclockwise 90 degrees.
    • Disconnect the three bundled cable connectors and the two power cable connectors from the motherboard.
    Pergunte ao FixBot
    Comentar
  5. TMY V08 Lens Replacement: passo 5, imagem 1 %32 TMY V08 Lens Replacement: passo 5, imagem 2 %32 TMY V08 Lens Replacement: passo 5, imagem 3 %32
    • Rotate the projector counter clockwise with the front facing you.
    • Remove the four 7.3 mm screws from the black cover to the left of the motherboard using a Phillips #1 screwdriver.
    • Remove the motherboard and black cover at the same time, being careful not to pull on the gold ribbon.
    Pergunte ao FixBot
    Comentar
  6. TMY V08 Lens Replacement: passo 6, imagem 1 %32 TMY V08 Lens Replacement: passo 6, imagem 2 %32
    • Flip the projector over so the bottom is facing up.
    • Remove the two 13.9 mm screws using a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  7. TMY V08 Lens Replacement: passo 7, imagem 1 %32 TMY V08 Lens Replacement: passo 7, imagem 2 %32
    • Flip the projector back over.
    • Remove the fine gauge adjustment, by lifting it out.
    Pergunte ao FixBot
    Comentar
  8. TMY V08 Lens Replacement: passo 8, imagem 1 %32 TMY V08 Lens Replacement: passo 8, imagem 2 %32 TMY V08 Lens Replacement: passo 8, imagem 3 %32
    • Grasp the side of the lens.
    • Pull the lens outward away from the hole while pulling upward to remove the lens.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 67
Ao todo: 1,492
