Ir para o conteúdo principal
Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement
O que você precisa
  1. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: passo 1, imagem 1 %32 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: passo 1, imagem 2 %32 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: passo 1, imagem 3 %32
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: passo 2, imagem 1 %32
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: passo 3, imagem 1 %32
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: passo 4, imagem 1 %32 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: passo 4, imagem 2 %32 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: passo 4, imagem 3 %32
    • Facing the inside of the front of the case, release the white ribbon cable by pulling the black rectangular connector at the end of the connection
    • Once the black holder is opened, gently pull the cable out of the holder.
  5. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: passo 5, imagem 1 %32
    • Facing the back of the small board, remove the two 2.0 mm Phillips #0 black screws that connect it to the back of the case.
  6. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: passo 6, imagem 1 %32
    • Carefully use a soldering iron to melt the solder in three places that connect the motion sensor. For more information on soldering follow this helpful guide.
    • Pull the sensor out from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 38
Duração total: 435
