Ir para o conteúdo principal
SuperSonic Matrix Mid SC-999 Battery Replacement
O que você precisa
  1. SuperSonic Matrix Mid SC-999 Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
    Pergunte ao FixBot
    Comentar
  2. SuperSonic Matrix Mid SC-999 Battery Replacement: passo 2, imagem 1 %32
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
    Pergunte ao FixBot
    Comentar
  3. SuperSonic Matrix Mid SC-999 Battery Replacement: passo 3, imagem 1 %32 SuperSonic Matrix Mid SC-999 Battery Replacement: passo 3, imagem 2 %32
    • Lift the back cover from the body of the device to expose the internal components.
    Pergunte ao FixBot
    Comentar
  4. SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: passo 4, imagem 1 %32 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: passo 4, imagem 2 %32 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: passo 4, imagem 3 %32
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
    Pergunte ao FixBot
    Comentar
  5. SuperSonic Matrix Mid SC-999 Battery Replacement: passo 5, imagem 1 %32 SuperSonic Matrix Mid SC-999 Battery Replacement: passo 5, imagem 2 %32 SuperSonic Matrix Mid SC-999 Battery Replacement: passo 5, imagem 3 %32
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Baylor, Team 6-1, Shaver Spring 2015 Membro de Baylor, Team 6-1, Shaver Spring 2015
BU-SHAVER-S15S6G1
4 Membros
Autoria de 18 guias
1Comentário do guia
Link to the soldering technique guide!
Josh Lewis - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 2,695
